Old 09-27-2009   #1
WTB: 16g stuff.
I'm switching to an EvoIII 16g, and I need an FP 4" to 2.25" coupler so that I don't need to buy a new intake. This one: http://store.forcedperformance.net/m...e=Acc-Silicone
I also need a J pipe that I can cut up to make work with my lower intercooler pipe.
Old 09-27-2009   #2
Re: WTB: 16g stuff.
Scheides used to have one of those couplers sitting in his garage, maybe he still has it.
Old 09-27-2009   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: WTB: 16g stuff.
I have a jpipe that I was holding onto in case I ever needed to cut one up. I'll see if I can find a pic.
Found it:
And no it wasn't me who did that
-1990 Mitsubishi Cyborg 4WD-
Old 09-27-2009   #4
Re: WTB: 16g stuff.
Found it:
What size is the pipe at the fitting there? 2" is ideal for the coupler to my LICP.
Old 09-27-2009   #5
Re: WTB: 16g stuff.
I have the coupler you need and a slowboy J-pipe and and custom one too with 2.5" outlet.
Old 09-27-2009   #6
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: WTB: 16g stuff.
99% sure it's 1 7/8. You can always cut it off at the flange and weld on a 2" pipe. That's exactly what I did to my other jpipe.
Old 09-27-2009   #7
Re: WTB: 16g stuff.
That's what I'm thinking I'll have to do. Since I won't be using the internal WG, I'm clocking the compressor housing so that the outlet points down like the Garret turbo I have now does.
Old 09-27-2009   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: WTB: 16g stuff.
Well then if you just used the flange and got yourself a 2" elbow and welded it on it would work great. If you found an elbow somewhere I could weld it on there for you too if you'd like.
Old 09-28-2009   #9
Re: WTB: 16g stuff.
I don't even think I'd need an elbow, just something that could compensate for the angle of the flange on the turbo since it doesn't come straight off like the garrett cover. My LICP goes across the bottom of the radiator, then comes up to meet the compressor outlet so that a straight coupler works. Also, I know how to weld and have access to a welder so I wouldn't really need you to do it for me. Thanks for the offer though.
Anyways, what would you want for the Jpipe?
Old 09-28-2009   #10
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: WTB: 16g stuff.
It's yours for 5 bucks.
Old 09-28-2009   #11
Re: WTB: 16g stuff.
Ok, if you're going to the Dyno day I could pick it up from you then.
Old 09-28-2009   #12
Re: WTB: 16g stuff.
Kevin, I have an SS Jpipe thats 2" but needs a bead welded on the end for the coupler. Ill bring it to the dyno day and give it to you for cheap if you want it.
Old 09-28-2009   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: WTB: 16g stuff.
I'll be at the dyno day. I'll be sure to bring it.
Old 09-28-2009   #14
Re: WTB: 16g stuff.
Ok, I'll be sure to take a look at your's too Peter.
