Old 11-19-2009   #1
Where to get timing belt tensioner tool
Not this:
http://www.amsperformance.com/cart/i...ioner_tool.jpg
But the tool used to twist the tensioner itself, it fits into the two holes:
I've used a few homemade ones, and while they got the job done, I'd like to find one that the pins don't bend on and you can actually fit a wrench on the nut once its twisted. I think MHI makes a tool for it, but I've heard other tools are out there. What do you use?
Name:	Screen shot 2009-11-19 at 9.22.26 AM.jpg
Old 11-19-2009   #2
blageo23
AWD4G64
blageo23's Avatar
Re: Where to get timing belt tensioner tool
I have one Chris, Ill let you borrow it if you need it. Otherwise Miller is the company that makes it. Also Jayracing sells a kit.
http://www.jayracing.com/index.php?m...index&cPath=17
1998 Spyder AWD
567hp
490tq
Old 11-19-2009   #3
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
That jayracing tool looks really nice!
Old 11-19-2009   #4
What is the miller one like? The jayracing one looks perfect, has anyone else used that? for $20, that fits the bill nicely (as long as it works good!).
Old 11-19-2009   #5
blageo23
AWD4G64
blageo23's Avatar
Here is the miller one. Same as the one I have.
http://cgi.ebay.com/ebaymotors/MITSU...motiveQ5fTools
1998 Spyder AWD
567hp
490tq
Old 11-19-2009   #6
Yummy, that one looks even nicer, no socket needed. Can you still fit a wrench on the bolt head ok with this tool? IT doesn't appear to have the notch cut out like the jayracing one does.
Old 11-19-2009   #7
I believe I bought mine from OTC tool in Owatonna.
Old 11-19-2009   #8
Constant_Project21
Constant_Project21's Avatar
Drives: E36
My buddy has a snap on one I believe. It's pretty awesome.
Old 11-19-2009   #9
^How do those compare to the ones blageo posted?
Old 11-19-2009   #10
I'm from Owatonna, you better buy from OTC!
Old 11-23-2009   #11
Well the OTC version has a hole in it to accept a 1/4" drive. I use a 1/4" to 3/8" adapter and an Dial Snap-on Inch pound torque wrench to set proper tension.
Realistically I've done 100+ 4g63/4g64 timing belts, not 1 failure. So I would imagine the part would be considered "good"
Chris,
If you want to just drive down and borrow mine, no worries. I just want it back in a timely fashion. It just depends if Savage is a good drive for you.
Old 11-19-2009   #12
Constant_Project21
Drives: E36
His is a stamped steel piece with the 2 prongs and a rubberized handle (no socket needed), I'd get a link but I'm on my iPhone.
Old 11-19-2009   #13
blageo23
AWD4G64
blageo23's Avatar
The Miller one has a radius on the bottom side(in the pic). you can fit a socket on the bolt easy. Honestly it works great.
Here is the OTC one. same as the miller one.
http://www.otctools.com/products/timing_belt_wrench
1998 Spyder AWD
567hp
490tq
Old 11-19-2009   #14
I used a ghetto version when I did my timing belt with just a 90 needle nose, and used the Jay racing style too. I really liked the jay racing style one because you can slide a socket over it or just use a wrench on it. All look like a good option though.
Old 11-19-2009   #15
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I have the OTC one... i believe i owe you a tool lending, let me know if you wanna borrow mine.
Style's automotive engineer
Old 11-19-2009   #16
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
I'd let you use mine but swifty has it (hint hint)
the one blageo posted is better, this lets you use a torque wrench to tighten the belt to factory spec rather than guessing, the snap-on/bluepoint one just has a handle sicking out the side
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
Old 11-23-2009   #17
There is like a 2ft-lb torque needed on the belt tension while you torque the eccentric pulley. I like Blageos, as Dave said, because you can properly torque it.
Old 11-23-2009   #18
Thx dudes! I don't need one right now, I just figure for $20-30, I'll buy one to have handy whenever I need it.
Old 11-23-2009   #19
s1ngletracker
Drives: A BMW
I think the value of that tool is overstated. You can apply the proper amount of torque by just pushing on the eccentric pulley with your hand (though a bit more trial and error is required to do that)
Old 11-23-2009   #20
On a DSM, you could probably do it with a screwdriver if you had to, but on an evo, you really need one of these tools. The tensioner pulley spins the opposite direction on 7-bolts and it is (of course) an awkward spot to put a screwdriver, angled pliers, etc. It's one of those spots I usually end up doing and re-doing a few times to get the tension right and timing marks all lined up. Having the right tool should hopefully help
