Old 12-03-2009   #1
santa
Boost Spike
santa's Avatar
Heard about a cool evo build?
Some evo up there I see? Looks like its got a lot of custom MAP parts on it!!! Details?? lol
Old 12-03-2009   #2
Re: Heard about a cool evo build?
The Evo X MR?
Old 12-04-2009   #3
santa
Boost Spike
santa's Avatar
The Evo X MR?
No, its a red evo 8. Custom MAP built top mount manifold and some other parts.
Old 12-04-2009   #4
^Before the dyno day you were acting like you worked at MAP and now you know nothing? :P Confoosed.
Whatever the project is, do share, sounds yummy.
Old 12-04-2009   #5
mlomker
*Resting In Peace*
mlomker's Avatar
I was wondering if that was Kasey's Evo 8 that was parked in there on the dyno day. I know that they bolted their prototype turbo on an 8 as well. Maybe that's what they're working on?
Old 12-05-2009   #6
santa
Boost Spike
santa's Avatar
Nope, its a full build big power car. It should make pretty good power!!
Old 12-05-2009   #7
santa
Boost Spike
santa's Avatar
I half way kind of sort of work there. lol. All the original map guys have been life long close friends. I've worked there on and off.
I'd share but, I'd rather let Chris.
Old 12-04-2009   #8
This thread = fail, at least so far
Old 12-07-2009   #9
v8klla
v8klla's Avatar
It's an Evo 9 RS that made its way up here from North Carolina, we're shooting for the stock ECU record (again) and 800+whp MAP 2.3L / Stage 5 Cylinder Head / Billet 6765...more info coming soon
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 12-07-2009   #10
Dang that thing's been there for a while now, how long until it's done? Get the lead out!
Old 12-08-2009   #11
b00stcreep21
I hate everyone
b00stcreep21's Avatar
There's a few pics of the manifold and turbo setup in the blog
http://www.maperformance.com/blog/
Old 12-08-2009   #12
Forced Fed
Drives: FS-T
Is that thermal dispersant on the inlet side of the turbo and the intercooler piping? Or is the thermal dispersant only on the intake manifold and a thermal barrier on the piping and turbo?
Old 12-08-2009   #13
v8klla
v8klla's Avatar
The intercooler piping and compressor cover are just powder coated I believe.
P: 763-545-3800
Old 12-08-2009   #14
FFPerformance
Correct. IC piping is powdercoated, as is the comp cover, and the rest of the exhaust components and turbine housing are ceramic coated.
FFPerformance is offline   Reply With Quote
Old 12-08-2009   #15
Forced Fed
Drives: FS-T
Would the inlet side and intercooler piping benefit from the thermal dispersant coating though like the intake manifold does? Would seem to make sense, since its suppose to pull heat out of something where powder coat traps it in.
Or does that thermal coating mainly work on heat exchanging things like a FMIC, Radiator, Oil Cooler, Intake Manifold, etc.
Old 12-08-2009   #16
FFPerformance
The thermal dispersant works best when there is any kind of airflow moving over it so whether or not we choose to use that coating, is pretty much application specific. In general though, we see +20-24% increase in cooling from the coating.
Actually the dispersant was originally designed for the military application of gun barrel cooling and was extremely effective. This technology eventually found its way into the automotive market as an aid for heat exchangers like oil coolers, radiators, and transmission coolers. Good stuff for sure.
-Bob
Old 12-08-2009   #17
The intake manifold touches the head, IC piping doesn't really get that hot. I doubt there would be noticeable gains.
Old 12-08-2009   #18
Forced Fed
Drives: FS-T
Makes sense and now after visiting MAP's website I have learned more about the coatings.
Thermal Dispersant is something you put on an Intake Manifold to help dissipate heat, where a Thermal Barrier is something you put on the Intake Manifold flange to prevent heat transfer from the head.
Old 12-08-2009   #19
Forced Fed
Drives: FS-T
Thanks Bob, answered everything I need to know! Thermal sprayed intercooler and piping would be worth it than on the application I have. I will be stopping by MAP over the summer once the snowmobile season is over to get lots of cold parts coated for my turbo snowmobile.
Old 12-08-2009   #20
FFPerformance
You bet man, we'll be here to help ya out!
