Old 01-09-2010   #1
CarPsyco84
CarPsyco84's Avatar
Manifold to turbo hardware.
Wondering what you guys like to use for bolts and gaskets for mitsu housing turbos, I used a grade 8.8 bolt before and they just stretched out from the heat, I don't know what the factory ones are made out of but those work good but now with a tubular manifold they are too long... any ideas?
Also they make gaskets bigger than the 7cm2 ones?
-When in doubt, Moar RPM.
Old 01-09-2010   #2
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Manifold to turbo hardware.
Couldn't you maybe use a dremel to cut them down? (Referring to the factor bolts)
Old 01-09-2010   #3
CarPsyco84
CarPsyco84's Avatar
No, they are only threaded at the very end, and besides I'm down to 1 cause the other factory one I had galled up and got tore up bad.
Old 01-09-2010   #4
I had nothing but problems with mine backing out. I currently use some standard Zinc plated socket head bolts I grabbed from work. Here was my final solution to stop them from backing out.
Old 01-09-2010   #5
CarPsyco84
CarPsyco84's Avatar
ahh, the old bike racer trick... thats a good idea.
Old 01-09-2010   #6
I just use some aircraft bolts and matcing locking nuts
Old 01-09-2010   #7
B, do you have the lock wire pliers? Or did you borrow that from work? I used to have a pair that somehow left with me when I got out of the NAVY, can't remember how that happened or what happened to them after that. I always loved aircraft solutions for car stuff.
Old 01-09-2010   #8
Nah I don't. We have a bunch at work, but I don't have any of my own. I just used Vice Grips to do the twisting for those bolts. I should pick up a pair though. I wonder if my favorite tool store (Harbor Freight haha) has some for cheap
Old 01-10-2010   #9
I have ARP bolts holding my turbo to the manifold and they work great.
Old 01-10-2010   #10
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
the factory most likely uses grade 10.9 metric bolts cause thats the strongest they make for the common bolts. other then that grade 8.8 is fairly strong but not great and i think its 12.5 that is stronger then 10.9 not positive tho, i just know its 12 something. only reason i know any of that is cause i work at a hardware store and get alot of bolts from here for my car.
mitsukid124 is offline   Reply With Quote
Old 01-10-2010   #11
mdost03
Sonic Champion!
Drives: VA STI
I had ARP bolts on my old car, worked great and the heads had the 12 pt socket heads to avoid stripping. They were awesome.
Old 01-10-2010   #12
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Sorry to kinda hi-jack but does anyone know if Ace sells 8.8 or stronger bolts for our cars? (M10 X 1.25)
-1990 Mitsubishi Cyborg 4WD-
Old 01-10-2010   #13
mitsukid124
Wink Re: Manifold to turbo hardware.
haha man thats where i work, they very well should, talk to a guy there about it and they'll make sure. but make sure its the metric grade not the standard grade, they're different. i also would recomond stainless so it doesn't rust. just personal preferance.
Old 01-10-2010   #14
CarPsyco84
CarPsyco84's Avatar
I know they have 8.8's cause Ive bought them there... dunno bought stronger
Old 01-10-2010   #15
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Can't decide if I should go ARP or just go to ACE.
Old 01-10-2010   #16
CarPsyco84
CarPsyco84's Avatar
how much are the ARP's?
Old 01-10-2010   #17
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
$20 at extremepsi. At least the shorter ones for a tubular manifold.
