Old 12-30-2009   #1
Aquamist HFS-2, HFS-3
http://forums.evolutionm.net/water-a...g-hfs-1-a.html
Pretty sweet! This is an evolution of the current kit I have, the HFS-1.
Old 12-30-2009   #2
Re: Aquamist HFS-2, HFS-3
So ya, this is an evolution of the HFS-1, featuring technology from the HFS-6 and old HFS-5 kits. They will feature RJ45 (same as your computer network connection) plugs for super easy wiring of the junction box. Wiring these things typically eats a good 45+ mins when I do installs, maybe more. The -3 kit will be pretty much the same setup as the HFS-1 except it'll have built-in boost trigger on top of the IDC (injector duty cycle) trigger. The -2 kit will not include the gauge or failsafe features and be much cheaper, but I would not recommend this option to anyone, as the very fact that they have a well-implemented failsafe is part of what makes Aquamist kits shine above all else!
ALSO, this just in:
Originally Posted by Richard L@Aquamist
The HFS-3 is very similar to the discontinued HFS-5, it mirrors the fuel flow at 1:1 ratio. You can change the ratio by sizing the water jet. However, it does have a gain trimmers to allow some form of rescaling to compensate for large fuel injectors that do not run up to 100%.
It does not have the full set of adjustments offered by the HFS-6.
The aim of this system is to update the HFS-1 to become a P&P progressive system at minimise cost to the end user. Utilising the PWM-valve setup to gain large dynamic flow range .
ZZOMG head 'splosion, so this is a PROGRESSIVE kit? Not a single-stage? It sounds like this is the case. I'm going to nail down what the exact differences are between the -3 and -6, so we can all make more educated buying decisions
Old 12-30-2009   #3
Please stop posting this crap. It makes me want to spend money.
Old 12-30-2009   #4
Not me u damn yuppies. Lol
Old 12-30-2009   #5
mlomker
*Resting In Peace*
mlomker's Avatar
At least you autocross guys have an excuse not to buy stuff--it could change your class. I have no willpower whatsoever.
Old 12-30-2009   #6
Screw autoX classes, torque = fun!
Or, keep your auto-X class, and just promise to leave the alky off, then when you hit the street:
+50whp/+50wtq with the push of a button (this is from my IX turbo setup almost 2 years ago)
Old 12-30-2009   #7
I gave up on that, hence why I was in SM this past year. Alcohol injection is legal AFAIK, nitrous is not. But it all depends on if you want to have fun, or be competitive. Or be like me and look for a co-drive in a competitive car and work on becoming a car slut.
Old 12-30-2009   #8
Alcohol is highly corrosive so if you run it, or are thinking about running it, check out this stock FPR from an Evo:
This was after 4 years running a 50/50 meth/water mix. Definitely something to keep in mind and watch out for since the alcohol travels into the FPR, BOV, brake booster, and everything else with a vacuum line attached to the intake manifold.
Old 12-30-2009   #9
Kasey at MAP
Drives: E-85 '03 Evo
Send a message via AIM to Kasey at MAP
Maybe that is because he was from MN. LOL
Kasey at MAP is offline   Reply With Quote
Old 12-30-2009   #10
^yea, I'm skeptical about that particular FPR issue, we'll see what becomes of it. I've been running alky for nearly 3 years now (SMC kit installed 1/13/2007) and never noticed rust when I had the FPR disconnected a few times.
Old 12-30-2009   #11
mlomker
*Resting In Peace*
mlomker's Avatar
E85 has a habit of eating pump socks, inexpensive fuel lines, etc. There's a price to be paid with anything.
Old 12-30-2009   #12
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Thats kind of a high price tag....
That is almost the cost of a standalone.
One of my thoughts was to leave the original system in place but have a secondary fuel system hooked to a smaller tank. You would have to add 4 more injectors but you could fill the smaller tank with whatever you wanted.
The 4 injectors would be progressively controlled and be shut of under a PSI
But now that I just reread all of this, thats a lot of work...
However there is the possibility of just running 87 octane in the regular tank and having premium (or E85) in the smaller tank (how often are we on the turbo anyway for the DD out there)
however I bet I could do that under $600... Fuel cost would make up for that eventually
I over thought this completely....
I had a question then about the injectors, what are they made out of so that they wouldn't corrode?
I haven't ever seen that much corrosion...
Old 12-30-2009   #13
Looks like the -3 will be a really nice setup!
Originally Posted by Richard L View Post
The HFS-3's adjustability is limited compared to the HFS-6.
It cannot (compared to the HFS-6):
- offset against the initial F-IDC - the F-IDC threshold % = starting point of meth flow %
- It doesn't have manifold pressure compensation
- alter the failsafe reset period = pegged at 3 seconds
- read "Direct Injection" pulses such as the 335i or Audi FSI pulses
- control a MAC valve directly as with the HFS-6
It can:
- put gain on the incoming F-IDC for purpose of having large fuel injectors running low DC. Previously, the HFS-5 has to be double pulsed.
- You can run the system based on boost or IDC only. In single or progressive mode.
- You can program it to be single point (HFS-1) or PWM-V mode (HFS-5).
The HFS-6 has futher electronic signal processing to match the FAV's opening and closing period. That is all I can think of so far.
IMHO this makes the -3 the kit to get, as you get progressive injection for the cost of a single-stage kit. Hopefully I can get my hands on a kit sooner or later and we'll see how it works
Old 12-31-2009   #14
This system is pretty amazing bang/buck now that I see how it works; I think I want one!
Anyone want to buy a HFS-1 kit?
Old 01-08-2010   #15
Old 01-08-2010   #16
bananas
bananas's Avatar
Drives: A4
anyone wanna buy an hfs-1 kit?
bananas is offline   Reply With Quote
Old 01-17-2010   #17
Group buy is open! http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=1748
Talk to MAP to see about getting in on it.
