Old 03-13-2010   #1
redline
redline's Avatar
Drives: GSX
Hit the dyno at DB today....
Got the car converted to E85 over the winter and had Shane re-tune it today. The car orginally made 513 at MAP on pump/meth mix last fall and since then I took out the Meth, went to 6an feed line and modded return line, added a Bosch 044 inline and swapped out to 1450 Bluemax injectors. Also had MAP ceramic coat the hot parts. The max run we did was only about 32 psi as the car was starting to push a little bit of coolant. Managed to just break 500 whp ( 583 whp converted ). Was pretty happy with the results, but I need to upgrade to some L19 studs and I need to work on my crankcase ventilation a bit.
- Big thanks to Shane for getting me in on such short notice!
Name:	new engine.jpg
ID:	9855   Click image for larger version
redline is offline   Reply With Quote
Old 03-13-2010   #2
DSM_brother2
Drives: to the shop
Re: Hit the dyno at DB today....
congrats man, nice numbers
93 talon tsi/ 6 bolt swap
Mitch
Old 03-13-2010   #3
Badass! Can you post a basic mod list? Fantastic numbers. Get some L19s in that thing and come on the cruise!
Old 03-14-2010   #4
redline
redline's Avatar
Drives: GSX
Sorry, that might help
gt35r ( .63 hotside )
Punishment T3 mani / 3in o2 housing into 3in full exhaust
Tial 38mm wg ( external dump )
BC 272 cams ( straight up )
BC springs / retainers
Mild port work on head ( 7 bolt )
Wiseco 8.3:1 pistons / eagle crank / rods
JM SMIM
2.5 IC piping / Tial 50mm BOV / spearco front mount
GM MAF / translator
DSM link V2.5
255 intake ( rewired )
bosch 044 inline ( seperate relay/full time run )
6an feed intank to rail
Aeromotive FPR
PTT twin disk
shep stage 3 tranny w/ 4 spider conv.
hallman mbc
I am missing a bit, but that's most of the important stuff...
Old 03-14-2010   #5
mlomker
*Resting In Peace*
mlomker's Avatar
Nice engine bay and plenty of power!
Old 03-15-2010   #6
Nice car! It should have more power in it once you get the head to stay down. You should be able to run 10s with it once it's all hammered out, if it doesn't already.
Old 03-16-2010   #7
Speedfreak
Drives: four tires
Relatively similar to my car, but is your motor a 2.0 or 2.4?
Old 03-17-2010   #8
Holy eff! If shane says the car is nice, it must be in great shape and have been a dream to tune. This is a huge compliment in my book, I'd love to check it out sometime! Come out to some events this summer, be sure to introduce yourself
Old 03-16-2010   #9
redline
redline's Avatar
Drives: GSX
It's still a 2.0
Old 03-17-2010   #10
Nice numbers!
1g 7 bolt head or a 2g 7 bolt head?
Old 03-17-2010   #11
redline
redline's Avatar
Drives: GSX
It's a 2G 7 bolt. Thanks for the compliments, I am pretty happy with where the car is at, but I still want to see just how much I can squeeze out of this 35R. With the small hotside alot of people have said that it will choke you up top pretty good, but from what we were seeing there is plenty left in it... plus can't complain about 30+ psi at 4400 rpm. I am trying to have the car ready for the cruise, but it's a DSM so we will see
Old 03-18-2010   #12
Well don't be too concerned about running 40psi on the cruise, most of what we do will be easy driving, twisties, and group stuff. There will be plenty of WOT, but you sure don't wanna blow it up while you're out where we're going!
Old 03-18-2010   #13
Plus scheides wouldnt like getting destroyed, hahaha.
Some other guy is making pretty similar numbers to you with a similar setup he is on tuners I think. I think he was 550ish on a mustang dyno.
Old 03-18-2010   #14
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
It's quite a nice car, and I'm happy to have played a role in installing parts on it. Good, clean setup.
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 03-18-2010   #15
It's real similar to my old setup as well. 20AWHP less on DB's dyno but mine was a 2.4 which makes the numbers about equal. Nice streetable setup that'll win most matchups.
Old 03-19-2010   #16
redline
redline's Avatar
Drives: GSX
The set up is a blast on the street, but I have a feeling I am going to have to do a cage shortly. I plan on squeezing a little more out of this set up and then probably gonna switch it over to an HTA35R with the .82 hotside and see how far the fuel system can go ....
Old 03-19-2010   #17
Hta82 or hta86?
Either should be good for ya!
Old 03-19-2010   #18
redline
redline's Avatar
Drives: GSX
Will probably go with the 86. Below is a link to quick video I did of both dyno runs.... not great quality, but getting there.
http://www.youtube.com/watch?v=Jru3abVi7Bw
