04-05-2010
Drives: 97 GSX Spyder/99 Chev S-10
4g64 95% Together
This is the 4g64/4g63 hybrid motor.. keeping the turbo stock for now until i get it all working right. its a big enough project the way it is..  .. This is the motor almost all put together.. still need to put on the galant cam gears and timing belt. then time it..
Reason: motors in now
04-05-2010
Re: 4g64 95% Together
Neat.
I hope you are not putting a T25 on this.
omfg you are...
Insta-spool at 1.5k? lolwut?
Your powerband will end at 4!
04-05-2010
its a SRT4 neon.
04-05-2010
Please please PLEASE tell me thats powdercoat and not spray paint on all of the hot parts
04-07-2010
powdercoat. yes t25 i'll upgrade later big enough project. lets get everthing in working order
04-08-2010
Even the head???
04-08-2010
Ok ok I high tempt it. What do you want from me! Haha but I did powder coat the parts that I could
04-08-2010
wants to be sideways...
Drives: Loud cars
Do you realize how hot your turbo and exhaust manifold gets?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
04-08-2010
ROFLCOPTER!!!
insta spool madness!!!!
i believe a 2.4 + t25 = fried turbo extremely fast?
and a fire from all the high temp paint perhaps?
lulz
04-08-2010
Drives: E36
Wooo, sounds like fun? I would strip all that paint off the head, that sounds like a bad idea.
04-08-2010
ok we'll see what happens... what if the paint is 1200 capable?
04-09-2010
DSMs get very hot, A good way to tell is go to a meet and ask people to pop their hoods, then take a non contact temp reader on some of the parts that you have used high temp paint on. You will be surprized at just how hot it gets. You can get the non contact temp readers for cheap from places like harbor freight.
It wont likely cause a fire, but it will smoke like hell with a nasty smell, then while it burns off it will look like crap.
04-08-2010
and it is going to be running low psi for now until i can get it all running correctly.. clean slate before upgrading
04-08-2010
1200... C or F?
04-08-2010
Doesn't matter, the head doesn't get very hot. The V8 guys paint aluminum heads for stock appearing classes, so it looks a little funny, but shouldn't cause any problems.
04-09-2010
Drives: a pos
if you want any help let me know. I live in the same town...
04-09-2010
x2
Originally Posted by scheides
04-12-2010
okay i'll check up on it
05-04-2010
got the motor in.. gettin things slowly together as i figure out whats beat up and whats good
