Old 10-29-2010   #1
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
Hmm. Properly remove oil feed line without bending?
Ok i picked up a small T28 Today. I can see the oil feed line is in there pretty good. It bends around and makes it even harder then ever. How can i get leverage without bending & twisting, trying to do this legit?!?! Any ideas welcomed!
Boostn2g is offline   Reply With Quote
Old 10-29-2010   #2
Re: Hmm. Properly remove oil feed line without bending?
It should be a flared fitting on a hardline, right? Similar to the fuel line connections?
Spray some PB blaster if it's rusty, and use a flare wrench on it. Once you break it loose it shouldn't be hard to get out.
Old 10-29-2010   #3
cmspaz
Walls need hugs too
cmspaz's Avatar
Also make sure to put a vice grips on the line to prevent from twisting it off, they generally rust up pretty good.
Originally Posted by Trogdor
Old 10-29-2010   #4
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
thanks much guys
