03-18-2011
DSM rear end work, combining a 3 bolt and 4 bolt
Is there information on this, I can't remember exactly but I believe it is good to use the internals from a 3 bolt in a 4 bolt.
I ask this because I have a 3 bolt rear end currently in my car and a 4 bolt waiting to go in, so this would be the perfect time to do something like this.
Thanks
Aaron
03-18-2011
'2of9'
Drives: Racer Van V6
Re: DSM rear end work, combining a 3 bolt and 4 bolt
IIRC, you can put the 4 bolt gears inside a 3 bolt diff...a few of GVR4.org people have done it. I'll try to find the thread and link it here.
ლ(ಠ益ಠლ)
03-18-2011
Thanks man. I'm probably just gonna run the 4-bolt as-is, but this is something I've always wondered about doing.
03-18-2011
What is the reasoning behind this?
Originally Posted by Tachyon
03-18-2011
2stepadepaaadepaaadep
Drives: myself crazy
wondering this also, is the 3 bolt casing lighter? or something of this sort maybe, interesting
Originally Posted by 311evo
03-18-2011
Drives: 2004 Corvette M6 F45
Mr. Lacroix has done this before. I believe it's the 3-bolt pinion in the 4-bolt housing make for a stronger set up.
03-20-2011
For the Galant VR4 guys it works well to swap the 4 bolt diff into the 3 bolt housing, keeping the 4ws is a plus. I heard a while back the 3 bolt ring and pinion is stronger then the 4 bolt. It takes some more time installing the 4 bolt diff, setting the back lash and gear pattern.
03-20-2011
I found for my uses a stock 4-bolt will be fine. Time to flush and fill.
Thanks guys.
03-20-2011
if you dont mind me asking, what are you gonna put in it?
03-20-2011
um, my dsm.
03-20-2011
um, my dsm.
You and not reading posts.  Are you wondering what kind of fluid or what?
03-20-2011
75 140 synthetic, or shock proof heavy. What else would you put in the rear end of a dsm.
03-21-2011
lol yeha sorry i guess i wasnt clear enough i mean what fluid are you gonna fill it with
03-21-2011
I just suck at reading, but read what john put, that is my exact same answer.
