Old 03-08-2011   #1
v8klla
v8klla's Avatar
MAP's Evo 8 & 9 Exhaust Manifold Testing / Dyno Results
Test Overview
As a follow up to our recent round of testing we decided to bring in another car and test every exhaust manifold upgrade that we offer for the Evo 8 & 9 platform I do not know the ins and outs of this car (perhaps Jake can chime in) but I do know that its on E85 with an FP Black and supporting mods (with the exception of the intake manifold). We set the boost level to 27psi and the only changes to the tune were made to bring AFR's back in line, enjoy!
Stock Exhaust Manifold vs. MAP Ported Exhaust Manifold
The peak gains here aren't all that exciting but there were some promising results in the mid range (+13whp +10ft/lbs with .5psi less boost) and spool improved as well. Please note the peak boost figure is a small spike around 4500, the rest of the boost curve is nearly identical.
Stock Exhaust Manifold vs. MAP "Short Runner" Tubular Exhaust Manifold
Again, the peak gains here aren't outrageous but the mid range gains (+29whp +22ft/lbs) are substantial and spool hasn't suffered one bit! At just $449.99 shipped the horsepower per dollar ratio is hard to beat!
Stock Exhaust Manifold vs. MAP "Long Runner" Tubular Exhaust Manifold
Our last round of testing featured our in-house fabricated "long runner" tubular exhaust manifold. Based on other tubular manifold test results we expected this manifold to significantly improve top end power with a negative impact on spool characteristics, needless to say we were pleasantly surprised
As you can see spool characteristics were very similar to the stock manifold and power output was nearly identical prior to 4500rpms. Peak gains were impressive at +23whp +12ft/lbs but once again the mid range gains (+41whp +31ft/lbs) are where exhaust manifold upgrades really shine!
Conclusion
Ultimately, I'm very happy with the outcome of this testing as I still feel there will be a market for all three of these great products. I would have liked to compare these manifolds at a higher boost level with an aftermarket intake manifold as I feel the performance gains would have been even greater, but that will have to wait until next time. I hope this testing makes your exhaust manifold decision a little easier!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 03-08-2011   #2
Re: MAP's Evo 8 & 9 Exhaust Manifold Testing / Dyno Results
Awesome. I want the Long runner. Anyone with a stock turbo call back with results with either of them?
Jake: Walmarts.
Old 03-08-2011   #3
Bi-winning?
On a side note, these are the awesome kind of posts I know a lot of people like to see.
Tests you guys might run and not think anything of might be helpful to the community.
Thanks guys.
Old 03-08-2011   #4
Wow, that's better than I expected. I might have to scrap my stock appearing theme just a bit.
Old 03-08-2011   #5
This was the one thing I have really caved on, never thought I'd be running a tubular manifold on a DD but the build quality is fantastic now-a-days. Nice job MAP!
Old 03-08-2011   #6
v8klla
v8klla's Avatar
We may have a solution for you
P: 763-545-3800
Old 03-08-2011   #7
cmspaz
Walls need hugs too
cmspaz's Avatar
My mind's been set on a ported stocker for when I finally decide I need more power, now I'm not sure any more.
Originally Posted by Trogdor
Old 03-08-2011   #8
311evo
311evo's Avatar
Ported stocker seems like a solid investment of you're on a tight budget. But considering how this manifold spooled and gained up top/mid I would say it's worth every penny.
The construction is amazing, and it quieted down my "tick" as opposed to my former thinner metal manifold. When I checked out the flanges and the ported transitions to the runners it was evident that they put a mind-blowing amount of time and thought into this manifold.
Old 03-08-2011   #9
Old 03-10-2011   #10
v8klla
v8klla's Avatar
California Special PM me for pricing haven't quite ironed it out yet.
P: 763-545-3800
Old 03-10-2011   #11
cmspaz
Walls need hugs too
cmspaz's Avatar
That... is incredibly awesome.
Old 03-10-2011   #12
Badass! Heat shields are good! These should be standard IMHO
Old 03-10-2011   #13
Mark Leasure
Mark Leasure's Avatar
Can't wait to pick up my long tube manifold, trading out the Megan, it’s the last crap part to be taken off the car.
Old 03-10-2011   #14
Spikesoftail
Spikesoftail's Avatar
Drives: 96 Talon Tsi AWD Auto
Wow, you guys make badass stuff even badasser!!
"Call amberlamps"
Spikesoftail is offline   Reply With Quote
