Old 03-24-2011   #1
v8klla
v8klla's Avatar
MAP's Evo X Exhaust Manifold Testing / Dyno Results
Test Overview
As a follow up to our recent Evo 8 & 9 testing we decided to bring in another car and test a few exhaust manifold upgrades that we offer for the Evo X platform I do not know the ins and outs of this car (perhaps Dave can chime in) but I do know that its on E85 and sports an FP Black with supporting mods. We used Dave's more conservative street tune for the testing, keep in mind that no changes to the tune / boost level / etc. were made during this testing so those numbers do fluctuate a little bit. It's also important to note that the baseline here is an MAP ported stock manifold, enjoy!
MAP Ported Exhaust Manifold vs. MAP "Short Runner" Exhaust Manifold
Boost was a touch higher between 4500-5500, but there were substantial gains throughout the power band! As you can see it spools a little slower but power output is very similar during spool up. +26whp & +13ft/lbs over our ported stock manifold for just $569.99 shipped? I think we had better place another stocking order!
MAP Ported Exhaust Manifold vs. MAP Tubular Exhaust Manifold for Evo X
Our in-house fabricated tubular manifold performed admirably with peak gains of 24whp & 18ft/lbs over the ported stock manifold, but we were surprised to say the least that it came in 10whp less peak than the short runner above (although the short runner appears to have been at a higher boost level when it achieved peak whp). We decided to make a revision to the routing of one of the runners and were pleasantly surprised by the results as gains up to +33whp & +26ft/lbs were realized Needless to say this revision will now be permanent.
MAP Ported Exhaust Manifold vs. FID Tubular Exhaust Manifold
In response to recent testing done by one of our competitors (and due to the fact that I wanted to see this with my own two eyes) we took it upon ourselves to order up an FID manifold and perform another comparison in house. Below you will find a comparison to the MAP ported stock manifold and then our revised MAP tubular manifold. Absolutely nothing was changed in regards to tune, in fact no MAP employee touched a laptop while in or around this vehicle (the owner logged the runs). Even with that being said I'm certain there will still be those that doubt the legitimacy of this testing, hate on haters as I saw what I needed to see
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 03-24-2011   #2
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: MAP's Evo X Exhaust Manifold Testing / Dyno Results
I don't think I need to comment my modlist on this site but I will on the other forums. Unless you want me to Chris.
Old 03-24-2011   #3
311evo
311evo's Avatar
I think we got it.
Old 03-24-2011   #4
Murlo26
Murlo26's Avatar
Originally Posted by 311evo View Post
I think we got it.
I figured as much Exactly why i didn't post anything.
Old 03-24-2011   #5
pictures of the revised manifold please!
Old 03-25-2011   #6
v8klla
v8klla's Avatar
MAP Long Runner in front, followed by our Revised Long Runner and then FID.
P: 763-545-3800
Old 03-24-2011   #7
Post it, I am sure not everyone has your mod list memorized. Copy/paste is easy
Old 03-24-2011   #8
Murlo26
Murlo26's Avatar
Well I wrote it elsewhere...people enjoy giving me shit for sharing info apparently.
But if you want it here:
Mods:
Buschur Bullet Exhaust
UR Testpipe
AMS Downpipe
AMS IC
AMS UICP/LICP
Primo 3.5" intake
FP black - ported heat coated
Blouch 21psi WGA
Built Motor - AMS Spec JE pistons, Manley TT rods, Cosworth bearings, stock sleeves stock crank
Built head - Ported/polished, +1mm valves (supertech) w/supertech springs
GSC S2 cams
Baseline w/ported n Coated stock mani - obviously changed manifolds
DW 1400cc Injectors
MAP AFPR kit
BlaqOps Progressive boost double pumper
E70 fuel
ACT 6 puck w/ ACT streetlite flywheel
Magnus CMC
Old 03-24-2011   #9
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Great results! Im sure Dave is Happy!
T-rev still #1 and lovin it!!!
t-revzr is offline   Reply With Quote
Old 03-25-2011   #10
550whp DD tune that's so legit!
Great results, thank you for sharing! Boost curves look closer than dave had described, that is definitely a key aspect to this kind of testing. Dave sent me a bunch of the logs and timing looked identical across the first round he sent, I have yet to review the second round.
Pumped to see the MAP Rev2 tubular mani make its way into production, and as always more data is good data imho.
Old 03-25-2011   #11
Murlo26
Murlo26's Avatar
^Like I said the boost curves I posted were just one run randomly from each to give an idea. There were definitely runs where boost was much closer.
Old 03-25-2011   #12
dzuest
ice shoes
dzuest's Avatar
Drives: 06' EVO MR
I assume FID and MAP are having a little manifold spat by the sounds of things...
What happened there?
dzuest is offline   Reply With Quote
Old 03-25-2011   #13
FiD posted Scheides' manifold testing results all over EvoM.
Old 03-25-2011   #14
Wat?
Old 03-25-2011   #15
Murlo26
Murlo26's Avatar
Scheides posted some, but FID posted all the results that Scheides didn't really plan to post where they upped the boost and what not.
I am guessing that is what Kracka meant.
Old 03-25-2011   #16
Among about another 10 threads FiD posted in and/or started which were all deleted shortly thereafter.
Old 03-25-2011   #17
Yea, we upped it a psi or two to try to match the psi that the car was running with the MAP exhaust manifold. That was after running it with no changes and it dropped a little bit of boost.
Old 03-25-2011   #18
Murlo26
Murlo26's Avatar
Which is another way to do the testing.
I don't think there is anything wrong personally with either way the testing was done.
I will say that if we tried to match boost on some of these manifolds the long runner from MAP would seem to come out on top as it dropped the most boost, but who knows.
One could go crazy trying to run the "perfect test". I don't think there is a perfect way to do it.
Old 03-25-2011   #19
It's going to be different from one car to another also. It's been known that a halfway decent tubular manifold is worth 30-50whp over a typical cast style manifold for 5+ years though. It's been proven on Hondas, 240s, DSMs, etc.
Old 03-25-2011   #20
nice thread tags
Tags
pending butthurt, pot stirring
