Old 09-16-2010   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Eagle Talon TSI AWD Turbo
Simple run down of the vehicle its a 91 AWD Talon as listed above. It is a turn key start car. The car hasn't given me any serious mechanical problems. Except for a Oil Pump and Transfer case that have been replaced. Oil changes done every 2500 miles. All the fluids have been exchanged within the last 5000 miles. The car has approx 154K miles on it. Its in good shape compared to other vehicles in the market. Ill be up front with everything, i do not want to waste your time so please dont waste mine. It does have a small rust spot which im in the process of fixing with a proper sand down and touch up paint. Its that small. It currently is my daily driver. Your welcome to test drive the car, check it out letting the car do the talking. Compression numbers were a little on the low side. Im open to offers and trades just let me know what you have in mind. Im best contacted by PM or cell phone 612 618 7252 feel free to make offers.
1991 Eagle Talon 1G
Modifications:
Engine:
Stock 6 Bolt Block (Ceramic Paint Coated)
ARP Head studs
Balance Shafts Eliminated
New PCV valve
New Oem Oil pump
Exhaust:
Ported 2G 02 Housing (Ceramic Paint Coated)
2.5" Custom Straight Turbo back Exhaust w/Magnaflow Muffler
*If buyer is interested i have a Tubular manifold as well Mitsu Flanged
Intake:
3" Short Ram Intake Pipe (Ceramic Paint Coated)
Ported MHI Evo 3 16G Turbocharger
3G 501 MAS
Throttle Body FIAV Blockoff Plates
Stock Non Crushed BOV
Fuel:
560CC EVO VIII Injectors ( Brand new Mitsu Dealer O Rings & Lower Injector seals)
Walbro 190 LPH Fuel Pump*
Electronics:
Eprom ECU w/Keydiver Chip
TurboSmart Boost Tee MBC
Drivetrain:
ACT 2600 Clutch Kit
Roller Skate Shifter Bearings
non-cruise throttle cable
Suspension & Brakes:
Option Import Front Strut Bar
Stainless Steel Rear Brake Lines
New OEM Mac Pherson Struts
Adaptive One Front Brake Pads* (Need Replacing)
NAPA Safety Stop Rear Brake Pads*
Blank NAPA rotors (Need Replacing)
New Tie Rods Both Sides
New Wheel Bearings both sides
New Front Passenger Caliper Needed
Interior:
2G DSM Leather Shift Knob
Exterior:
17 Inch OZ Race Wheels
Tire size 215/45R17
Miscellaneous:
FIAV Eliminated
Emissions Eliminated
A/C Eliminated
Cruise Control Eliminated
For the bad
-Headliner missing
-Right Front Passenger Side Caliper Needs To Be Replaced
-Handbrake Needs Replacing
-Needs New Front Brake Rotors soon
-Passenger seat belt dosnt automatically retract by its self locked in the secure position. (Most likely is a fuse i still need to look into the problem)
-Compression Between 130-120 across the board. (Not necessarily bad) Still pulls nicely
-A Pillar trim missing both sides.
Asking Prize 3500 OBO 3500 might seem steep but its a starting point. We all go into this game not expecting to make the money we put into the car back. I just need enough for a GVR4 i have been looking at. So feel free to make offers here and there. Contact info is 612 618 7252
