Old 02-21-2012   #1
Swanny
Swanny's Avatar
Drives: 2G Talon
Bad Heater-Core, 2G, Bypass??
I've searched and still am searching, I cant find a write-up on bypassing the heater-core, would I be able to bypass without removing the dash?
Thanks
Swanny is offline   Reply With Quote
Old 02-21-2012   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: Bad Heater-Core, 2G, Bypass??
Yes you can bypass it with out removing your heater core. open your hood and look for 2 coolant hoses going in to the firewall. After that you should be able to figure it out.
Old 02-21-2012   #3
Swanny
Swanny's Avatar
Drives: 2G Talon
Wait, Do i just connect a male to male fitting to the coolant lines on the firewall?
Old 02-21-2012   #4
Swanny
Swanny's Avatar
Drives: 2G Talon
Haha ya thanks, seems we posted at the same time I answered my questions! thanks sr
PS What size are those coolant lines?
Old 02-21-2012   #5
I would remove the existing rubber lines and just run a U shaped loop to the lines below/behind the thermostat housing. From what you described above it sounded like you were going to keep the rubber lines in and loop them back where they enter the firewall.
Old 02-21-2012   #6
Swanny
Swanny's Avatar
Drives: 2G Talon
Correct. I was assuming you can pull the 2 lines from the firewall and use a male to male connection to keep a open loop there... You suggest running one "U" shapped solid line from the housing instead? What size are these lines, 5/8"?
Old 02-21-2012   #7
Well, if you dont need all that coolant line going to the firewall and back, why keep it? I'm sure you can find a U shaped hose in the right diameter if you look around for some.
Not sure on the diameter. Drain your coolant, take the hose off, and bring it to a parts store to see what they have in stock in that diameter.
Old 02-21-2012   #8
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Alex you need to sell that thing already!
