Old 06-09-2012   #1
Bunch of stuff cleaning the garage
Have a halo cas with the plug it has 4" or more of wire with it
60.00
Also have a 1g 94 na t.b. has all sensors on it came off a running car
40.00
3.0'' xo2 racing straight hump 4 layer 3.0''L
10.00
2.0" to 2.5" HTS 90* 4 layer legs 3.25" (2.0" side) 1.5" (2.5" side)
15.00
New 2.5" HTS 90* 4 layer legs 5.25"
30.00
Have a set of daytona rota center caps. they came with a set of takata green grinds I bought and have no need for the caps.
They still have the plastic on them all and are unused
I would also trade for a set of carbon style rota caps.
30.00 set
98 eclipse tail lights tinted with ppg dbc500 with black base coat for tint and ppg clear coat.
50.00
stock tails
30.00
97-99 awd 1/2 shaft has good bearing 75.00
2g cruise control set up 25.00
Full 97 ac system pulled from working car will sell as whole or in parts
Also have a ton of parts left from parting out the 97 awd Spyder and 95 talon tsi and alot of other parts from the 50+ other Dsms I parted over the years.
Old 06-09-2012   #2
2G.S.X.
2G.S.X.'s Avatar
Drives: 2G GSX Eagle/Wiseco Hi-Comp. 6bolt, Evo III 16G
Re: Bunch of stuff cleaning the garage
How much for that A/C system?
2G.S.X. is offline   Reply With Quote
Old 06-12-2012   #3
Adding
2g non cruise throttle cable SOLD
2g non abs set up. All the lines non are striped out,brackets,and p. Valve
75.00
Old 06-16-2012   #4
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Do you by chance have 2g battery tray, 2g battery "L-bolt" and hardware for it, just a M8x1.25 nut and washer, 2g N/T battery hold down P/N: MB920556.
If you can't afford to buy an EVO, might as well beat an EVO
Boomdeeze is offline   Reply With Quote
Old 06-16-2012   #5
Might have the bolt and tray still will have to look. I don't have any 2g 420a parts
Old 06-16-2012   #6
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Well you have my number so just text me when you look.
Old 06-16-2012   #7
Holy crap if you sold all those Mitsus you could get a nice car!
