09-18-2012
Boost Spike
1993 Eagle talon tsi built race car (auto)
I'm deciding to get out of the dsm game and sell my 93 eagle talon. It's time to move on for me. Its in really great shape with zero rust on it. I swapped a auto into the car last year when I bought it. I bought the car as a roller and intended on doing some serious drag racing with it. I had Richard Brown at meanstreet performance put a chromoly 10 point cage in the car (It is certified to 8.50's). He also tubed the front end on the car for me which you can see in the pictures. Onto the good stuff.
Engine:
2.3lt stroker Map ultimate duty connecting rods, malhe 2.3lt pistons (9.5:1)
A1 h11 headstuds
felpro permatorque headgasket
no balance shafts
arp main studs
kiggly main girdle
-16 line in head for crank case ventilation
2g awd auto starter (new this year)
Turbo system:
PTE 6765 billet CEA T4 turbo .58 ar exhaust housing,
Tial mvs 38mm twin wastegates
Custom built top mount tubular exhaust manifold (Made it myself)
Black thermal coating on the turbo and manifold
Head:
ferrea SS 1MM over sized intake and exhaust valves
Super Tech dual valve springs
Manley titanium retainers
map stage 5 port and polish treatment
New bronze valve guides
crower 415 cams (288's)
AEM Adjustable cam gears (new within the last 2 months)
Gates kevlar timing belt
Magnus V3 cast intake manifold
Q45 TB cut down on a lathe to make it all nice!!!
all SS ic piping, upper pipe is 3.5''
Tial 50mm BOV
xspower massive front mount 4'' thick 12'' tall, 30+'' long
B&M supercool trans cooler with SS lines, and fan on back
Vistion aluminum radiator (full size)
Drivetrain:
2g awd auto transmission
Kiggly 2g in a 1g kit
kiggly flex plate
kiggly extended dowel pins
kiggle front clutch upgrade (3rd gear holds 30% more tq)
Precision industries 3500rpm stall
DSS stage 5 rear axles
Welded center diff
driveshaft loop
Interior:
Evo 8 recaro front seats
5 point gforce harnesses (drivers is still good for 2 more years)
Electronics:
DSM link V3 set up on a 3.5'' gm mas.
AEM twin fire ignition box
aem wideband
aem boost gauge (5bar)
aem trans temp gauge
Pro sport oil pressure (integrated into cluster)
Pro sport coolant temp (also integrated into cluster)
TCI pro outlaw shifter (custom mounted)
NSS is hooked up and works properly
Talor battery box mounted in the back.
Kill switch located in the back (behind license plate)
Suspension:
K-sport pro coilovers (new this year)
2 piston front brakes
rotor pro front rotors (slotted)
Hawk hps pads up front
Rotor pro rear rotors (slotted)
SS brake lines up front (kit I got only had fronts for some reason)
DSS stage 5 rear axles (as mentioned perviously)
17x7 black rims Akuza Road concept rims
Perelli P6 Four season tires 225 45 R17 (almost brand new tires) Great tread
Fuel system:
Fuelab Prodigy fuel pump 1500hp version
-12 feed to fuelab ss element fuel filter
-8 out of the pump to ss fuelab fuel filter
-6 return line
Aeromotive a1000 FPR (liquid pressure gauge)
FIC highZ 2150cc fuel injectors
FIC fuel rail
There might be a few things that I'm missing as far as mods go. The car is currently on 25-26 psi and feels great. Will need a Driver side lower ball joint, and a alignment (should get it corner balanced). I have over $20k invested. Sold as is. Have clear title in hand.
Vin: 4E3CG64F8PE036356
mileage: 93,XXX
Price: $7500 (I'll throw in the set of FD rx7 wheels and tires I have currently for sale as well.
Car weighs 2900lbs with me in it ( I'm 150lbs )
pm for fastest response, I'll pm you my number
Thanks!!
09-18-2012
Re: 1993 Eagle talon tsi built race car (auto)
holy shit, deal of the century
09-18-2012
Boost Spike
True story!
09-18-2012
Agreed, well priced but realistically what you get.
I'm sure you have heard this from other friends, but partout? we all know its the best way to get your money out of it.
Good luck.
09-18-2012
Drives: cbr 1000rr repsol
Hmm my bike is for sale. If that actual sells I will send you a pm
09-18-2012
Boost Spike
By the way the car still has heat
09-18-2012
Drives: 91 fwd stealth tt/ 99 SL
Damn I wish I didn't buy my nova. You interested in a nova?
09-18-2012
Mitsus for days!
Drives: '08 Chrysler 300C
Hell, I wish I had about $10,000 right now. lol
09-18-2012
Boost Spike
Pm me details on the nova.
09-19-2012
pm sent
09-19-2012
Got Boost o_O'' m
Why  so much invested . . .will you ever be back ...these things are addicting
09-19-2012
Way too cheap Kevin. Good luck to you and whoever buys it though! Hopefully it goes to a good home
Originally Posted by scheides
10-09-2012
Anyone know if this has been sold?
10-09-2012
It was sold, currently being de-hackified.
10-09-2012
Good to hear. Should make a very nice and fast car for the new owner once cleaned up.
10-09-2012
Local guy buy it?
10-09-2012
yeah, blackawdtsi was the lucky guy. ha
10-09-2012
Thats Tom right? What a sneaky bastard haha
10-09-2012
Wow, never saw that before, that was a hell of a deal.
10-09-2012
^Yeah, motor might be back together for passes this weekend or next.
