Old 11-05-2012   #1
bigboostingst
bigboostingst's Avatar
Drives: AWD Spyder
MHI TDO6 20g ready to bolt on!
Im looking to sell my mhi 20g turbo in hopes of going bigger. This turbo makes great power and the spool is comparable to an evo III. It has been a very, very fun street turbo. The wastegate has been welded shut for an external setup. It has a tiny bit of side/side shaft play, but is not in need of a rebuild and does not smoke at all.
I'm looking for $400 obo
763-4oo-1235
Old 11-09-2012   #2
bigboostingst
Drives: AWD Spyder
Re: MHI TDO6 20g ready to bolt on!
PM's replied to. Dropping price to $380! Also interested in trades!
Old 11-12-2012   #3
bigboostingst
Drives: AWD Spyder
Lots of interest but nobody has shown up yet. $360
Old 11-16-2012   #4
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
300 I'll pick it up. besides injectors, is there anything else you need to tune for v3 for a base setup?
dsm_talontsi is offline   Reply With Quote
Old 11-16-2012   #5
dsm_talontsi
Old 11-16-2012   #6
No way a TD06 20g is comparable to a 16G.
Old 11-16-2012   #7
dsm_talontsi
Sweet, some injectors, afpr and ill be good
Old 11-16-2012   #8
It will be a lot laggier, might make a bit more power than a e316G, but I haven't played with one to see, actually I think tachyon might be but his car is built around that setup so its rare.
Old 11-16-2012   #9
dsm_talontsi
Well im running stock 14b right now and its pulling hard on stock boost. (fwd by the way). And does it bolt right on?
Old 11-16-2012   #10
Tachyon
Tachyon's Avatar
Drives: Icarus
The TD06 will provide more lag - dependent on the exhaust housing size. I did PM the OP for the housing size. Being you're FWD, you probably would enjoy the larger turbine wheel and housing.
I currently rock the TD05 turbine in a 6cm housing on a 2.4 and that will produce around 20 psi by 3800 RPM. My best guess is the TD06 in a 060 or 070 would be about 800 RPM later on 2.0 than my TD05 2.4.
With FWD, E85, and required supporting mods this turbo will go past 500 WHP on a DJ.
Hell of a bargain.
-Sebastian Vettel
Old 11-16-2012   #11
dsm_talontsi
Hell of a bargain.
I guess my goal right now is around 4-450. Im trying to stay away from e85 until spring
Old 11-17-2012   #12
bigboostingst
Drives: AWD Spyder
I never said the turbo was comparable to a 16g, only that the spool was comparable. I wouldn't classify 300 RPM later spool as "a lot" but to each their own. Either way the turbo was sold yesterday, thanks for the offer anyways though!
Old 11-16-2012   #13
^lol. Pulling hard.
