Go Back   MitsuStyle > Tech > The Good Stuff
Old 07-02-2009   #1
Evo Gearing Chart
This is good info so I figured I post it up in a separate thread.
This is assuming you are running stock sized tires on each car.
For gas milage considerations, here is a break down top gear RPM at various cruiseing speeds on the highway.
speed . . . AWD DSM. . . . . EVO VIII. . . . . EVO IX. . . . . EVO MR
55 . . . . . . . . 2425 . . . . . . . . 2365 . . . . . . . 2500 . . . . . . .2305
60 . . . . . . . . 2645 . . . . . . . . 2580 . . . . . . . 2730 . . . . . . .2515
65 . . . . . . . . 2865 . . . . . . . . 2795 . . . . . . . 2955 . . . . . . .2720
70 . . . . . . . . 3085 . . . . . . . . 3010 . . . . . . . 3185 . . . . . . .2930
75 . . . . . . . . 3310 . . . . . . . . 3230 . . . . . . . 3410 . . . . . . .3140
80 . . . . . . . . 3530 . . . . . . . . 3440 . . . . . . . 3640 . . . . . . .3350
85 . . . . . . . . 3750 . . . . . . . . 3660 . . . . . . . 3865 . . . . . . .3560
And for full throttle acceleration considerations, here is a break down of what speed you are going at the top of each gear just befor shifting to the next higher gear (assuming shifting at stock redline of 7,000 RPM) and what RPM you enter the next higher gear at.
Gear . . . . AWD DSM. . . . . . . EVO VIII. . . . . . . . EVO IX. . . . . . . . EVO MR
1st . . . . . 34.4 (3800) . . . . . 40.0 (4700) . . . . 42.1 (4900) . . . .39.8 (4700)
2nd . . . . . 62.8 (4650) . . . . 60.1 (5150) . . . . 60.1 (5200) . . . .59.6 (5200)
3rd . . . . . 94.8 (5250) . . . . . 83.2 (5150) . . . . 81.1 (5300) . . . .80.8 (5350)
4th . . . . . 126.9 (5600) . . . 113.6 (4900) . . . 106.9 (4850) . . . .105.3 (5500)
5th . . . . . 158.7 (N/A) . . . . 162.7 (N/A) . . . . 153.9 (N/A) . . . . .133.7 (5600)
6th . . . . . N/A (N/A) . . . . . . . . N/A (N/A) . . . . . . N/A (N/A) . . . . .167.1 (N/A)
Old 07-02-2009   #2
Re: Stock Evo Gearing Chart
Makes me wish I had the MR with 6-speed instead.
Old 07-02-2009   #3
311evo
311evo's Avatar
Good info, thanks for posting!
Old 07-02-2009   #4
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
Nah, i wouldnt lose sleep over it. Your car is sick as it is man.
BLaCk_1cE is offline   Reply With Quote
Old 07-02-2009   #5
I've always wanted the 6-speed for the very reason of lower highway cruising RPM.
Old 07-02-2009   #6
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: Evo Gearing Chart
Even an Evo VIII would be nice compared to the IX. OH well.
Old 07-02-2009   #7
I never realized IX gearing was so much shorter than VIII.
Old 07-13-2009   #8
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
I sure did...
Just wanted to add that you can go around 126mph at the top of fourth on the MR tranny at 8500rpm.
Old 07-14-2009   #9
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
One of the primary reasons why I wanted the MR w/ 6-speed. I was so spoiled with my TT Stealth and it's 6-speed. Barely turning 2000 RPM @ 70 MPH in 6th - great touring gear.
Old 05-09-2011   #10
All scheides' talk about X gearing in his project thread got me to thinking about the gearing on those things. Is it much different from 8/9's? Anyone done a log good enough to add to this first post?
Old 05-09-2011   #11
mlomker
*Resting In Peace*
mlomker's Avatar
A Is it much different from 8/9's?
I recently had to look this up to configure the data logging software that I'm using at the track. My software just required gear ratios and max speeds at stock limiter.
Final drive: 4.68
Gear 1: 2.85 (43mph)
Gear 2: 1.95 (63mph)
Gear 3: 1.44 (85mph)
Gear 4: 1.09 (112mph)
Gear 5: 0.76 (161mph)
Old 05-10-2011   #12
I'm just excited about the longer first gear in the Evo, I hate that every day when I drive my GSX. Evo's just about done.
Old 05-10-2011   #13
X GSR gearing is the same as IX GSR gearing.
Old 05-10-2011   #14
So the stock redline on X's must be 7500?
Old 05-10-2011   #15
Indicated redline is 7k just like the DSM/8/9 and I think rev-limit is up around 7,500 just below where the 8/9's is.
Old 05-10-2011   #16
Holy short gearing Evo IX GSR.
Old 05-10-2011   #17
mlomker
*Resting In Peace*
mlomker's Avatar
Angry Re: Evo Gearing Chart
High rpms at freeway speed is a frequent complaint...you know, from people that actually don't like sports cars.
Old 05-10-2011   #18
Yeah I really don't see what the concern is. It's an Evo, not a Corolla. The high-revs aren't hurting the engine any and the gas mileage isn't that bad considering the nature of the car.
Old 12-15-2012   #19
Figured I would post my findings for FWD DSM's. The 2g turbo FWD's 1st gear is a tiny bit shorter, but it makes less than 1/10th of a mph of difference.
This is also using stock sized tires on each car.
Speed . . . FWD Turbo DSM. . . . . FWD N/A 1g DSM
55 . . . . . . . . . 2250 . . . . . . . . . . 2375
60 . . . . . . . . . 2500 . . . . . . . . . . 2600
65 . . . . . . . . . 2750 . . . . . . . . . . 2800
70 . . . . . . . . . 2950 . . . . . . . . . . 3000
75 . . . . . . . . . 3200 . . . . . . . . . . 3250
80 . . . . . . . . . 3400. . . . . . . . . . 3450
85 . . . . . . . . . 3600. . . . . . . . . . 3675
And for full throttle acceleration considerations, here is a break down of what speed you are going at the top of each gear just before shifting to the next higher gear (assuming shifting at stock redline of 7,000 RPM) and what RPM you enter the next higher gear at.
Gear . . . . FWD Turbo DSM. . . . . . . FWD N/A 1g DSM
1st . . . . . . 39.8 (4125) . . . . . . . . . . 36.5 (4050)
2nd . . . . . . 66.9 (4850) . . . . . . . . . . 63.2 (4650)
3rd . . . . . . 96.6 (4900) . . . . . . . . . . . 95.5 (5100)
4th . . . . . .138.2 (5850) . . . . . . . . . . 130.7 (5650)
5th . . . . . .165.6 (N/A) . . . . . . . . . . . 162.3 (N/A)
