Old 05-24-2004   #1
SlowWhite
Been there, done that.
SlowWhite's Avatar
Just realized I have a few more things to buy before I can finish my car.
and Slim line FAns are one of them
I'm wondering:
-which ones to use
-how much CFM should I go with
-where should I buy them from
-Which Style (push or Pull?)
FYI - I don't have my A/C decrompressor anymore so I have a space between my FMIC and Radiator.
I've been battling a high temp problem for some time now. So I also need to get a lower thermostat. Any idea's there as well?
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 05-24-2004   #2
If you look on ebay you can get 2 10" fans for $75. Ryan has them on his galant and there really nice fans, and a good price. As for the thermostat try just about any dsm vendor, dsm motorsports I think sells lower temp ones. Also you are going to want to try just water with ither dish soap or water weter.
Old 05-24-2004   #3
Enes
Enes's Avatar
I'm in that boat as well, i need a slim line fan, my turbo is getting in the way... damn turbos...
i took out the ac so there is plenty of room for a fan in the front of the radiator, should i just go with the push one?
-E
Old 05-24-2004   #4
just about any aftermarket fan can be switched to push or blow, so putting them infront of the radiator is a really good idea, saves room for massive turbos.
Old 05-24-2004   #5
Enes
Enes's Avatar
Thing is i should have the car running tonight, so i need something localy... any local shop that caries them in stock...
-E
Old 05-24-2004   #6
checker, $80 for 1 10" fan.
Old 05-24-2004   #7
SlowWhite
SlowWhite's Avatar
You recommend 10" over 12" - also what CFM are they putting out?
I don't have access to Ebay, nor do I have a credit card. So I'll have to buy them from a local shop.
I'd like to put the Fan in Front of the Radiator so that when I have to work on my car, I'll have more room. But what I'm also wondering would it be better to do 2 fans one in front and one behind that way the Motor/turbo itself get's air over it to help cool?
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 05-24-2004   #8
Enes
Enes's Avatar
probably better off with 2 in front of the radiator...
i'll look at a local checkers or something.. hopefully they are like dual speed or something...
-E
Old 05-24-2004   #9
john
Business as usual
john's Avatar
You don't need any fans in your car unless you plan on sitting at idle for a while. I haven't had fans for a couple months now and have never overheated. Just keep moving . Don't beat the shit out of the car and pull over and talk to your friends. Just keep driving down the freeway. BTW, I am going to be getting some.
97 Viper GTS
Old 05-24-2004   #10
Enes
Enes's Avatar
so basicly what you are saying is you need one
Old 05-24-2004   #11
john
Business as usual
john's Avatar
No, I dont NEED one, but I am going to get one anyhow. I have never overheated my car. All you have to do is use common sense.
97 Viper GTS
Old 05-24-2004   #12
SlowWhite
SlowWhite's Avatar
Well My car runs 216 degree's just by driving it. (cruising)
so it's hot enough as it is.
By August I plan on getting a Fluidyne to go with the Fans. And maybe carbon Fiber hood with some sort of Vent system designed in it.
I just want more airflow in the engine bay, which I'm hoping in return with help several things.
Intake Temps, coolant Temps, overall put a higher rate of Air flow over all engine parts, as well as possibly increase Air flow over the K&N
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 05-24-2004   #13
Without reading at all about fans but using what I learned this past semester about hog confinement ventilation, for fans you need to look overall at two things: efficiency and deliverable CFMs. Brand may or may not mean shit depending on the two factors I just listed. I would sure hope that somewhere along the line someone has done testing on automotive fans similar to what Bell Labs does for the agricultural industry.
Old 05-24-2004   #14
SlowWhite
SlowWhite's Avatar
Hense why I asked about CFM.
I don't necessarly want cheap - I want quality/a lot of CFM, and good price, and somewhat easy install.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 05-24-2004   #15
Enes
Enes's Avatar
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
how does that look,
12² Fan
Specs
CFM Pull
1200-1450
CFM Push
1350-1550
Dimensions
11-3/4² x 12-1/2² x 2-1/2²
Amps (push or pull)
5.5 +-0.5 AMP
Volts
Manufacturer
Generic
Country of Origin
Unknown (suspect Asia)
i could buy two and sell you the other one?
-E
Old 05-24-2004   #16
Enes
Enes's Avatar
or a 10" one
Old 05-24-2004   #17
illz
if you want to keep your shit cool, first choice are the stock fans with full shrouding. they cool better than 95% of aftermarket setups.
if you cant fit them, get a SPAL 12" high performance for the passenger side, and a SPAL 10" regular for the A/C side. The high performance models are 3.7" deep, the regular ones are 2.05" deep. Generally on the A/C side you'll need the extra clearance for turbo/manifold/piping/etc. The 12" high performance comes in both straight and curved blade styles, the straight blade is much higher flowing, but a lot more current draw. The curved is a good in-between, and will flow around 1400cfm. The 10" regular flows around 650cfm. Visit http://www.jaycorptech.com to see detailed specs and sizing for all SPAL models. I'm sure elite can get them for you.
Make sure they are flush up with the radiator, and try not to bend up the fins too much on install, though if you don't have the fluidyne yet your fins probably aren't that flimsy
DSM + FWD = Carl Lewis in high heels
DSM + FWD + slicks = Michael Johnson in birkenstocks
illz is offline   Reply With Quote
Old 05-24-2004   #18
1Fst14B
Send a message via AIM to 1Fst14B
if you are overheating/have high temps crusing down the highway, you have other problems.
My car did this and had a bad headgasket.
kevin ran around for a very long time without a fan, even in the summer i think, without any problems, but would start to get hot if idled at a standstill for too long.
try a thermostat first, or take it out.
After i fixed my HG, temps never rose over like 150 (without a thermostat) unless it would idle forever...
Adam
1Fst14B is offline   Reply With Quote
Old 05-24-2004   #19
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
The ones Enes liked to in his second post are the ones I have. Same person and everything. My temp is ALMOST ALWAYS 197*F. Except at the end of a long pull (It's still 197/198 at the end of a 1/4 mile run), then they might be higher. I can't give fans the credit for that really though, most of it is just having a good cooling system, with a no problems.
Old 05-24-2004   #20
Enes
Enes's Avatar
do you have it as pull or push right now?
_E
