Old 07-06-2013   #1
Speedfreak
Drives: four tires
WTBorrow Injectors
Halon came over and helped me diagnose the dsm. Thanks again Brandon. Looks like the injectors may be the problem. Car started with starting fluid sprayed in, and we checked all components up to the injectors.
Anyone have a set of injectors(preferably around 1200cc) I can swap in and see if the car starts?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 07-06-2013   #2
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: WTBorrow Injectors
I have 880s. Message me if those would work
Old 07-06-2013   #3
Speedfreak
Drives: four tires
If nothing else closer(size) is available by tomorrow, I'll message you.
GSX - 571whp/490wtq
Sienna
Old 07-07-2013   #4
97gsexx
97gsexx's Avatar
Drives: 97 talon
I have some fic bm 1050's you could use. Pm me
Old 07-07-2013   #5
Ditch the AEM.
Old 07-13-2013   #6
Speedfreak
Drives: four tires
880's above were sold and the 1050's are being used by mark4g63t(1600cc thread).
Anyone else have any injectors I could borrow for a couple hours?
GSX - 571whp/490wtq
Sienna
Old 07-13-2013   #7
I only have hi-z 2150s if not you would have my set already.
Old 07-13-2013   #8
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I have a few stock sets but I am in Winona... If you dont find any by Monday I could always ship ya a set for a couple days or a week. Let me know.
Originally Posted by shoutbox
Old 07-13-2013   #9
Speedfreak
Drives: four tires
I'll definitely consider this, I'll let you know(I'll pay the shipping both ways if we do this).
GSX - 571whp/490wtq
Sienna
Old 07-13-2013   #10
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
507.313.2109 - Text is usually best.
Let me know whenever. They would be there by Tuesday.
Old 07-14-2013   #11
Does anyone know what the required voltage is to trigger a set of Low-Z injectors are?
Old 07-14-2013   #12
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
You can trigger an injector with 4-5v but the power side of the injector should be battery power. If you check voltage at the plug, it should be the same voltage as the battery is what I mean to say...
If you have a noid light and that flashes, that is plenty of power to drive the injector.
Old 07-14-2013   #13
Even on DSM with the resistors? We were seeing around 8-9v at the plug and they wouldn't fire. Sense why we wanna try a known good set of low-z injectors to verify it is the injectors. But in the back of my mind wondering if it could just be not enough voltage to drive low-z injectors?
Old 07-15-2013   #14
Not having enough voltage during cranking is often a problem that cars with 1600s have, they require a lot of voltage to open, I am not sure with those 1200s. I have a bag of random 1200s, but not sure which ones are good and which ones are bad. They fail a lot of E85 cars.
Old 07-16-2013   #15
No-one has stockers around?
You could try evo injectors I think.
Old 07-16-2013   #16
Speedfreak
Drives: four tires
Yeah I need known good injectors so I can rule mine good or not.
Well the tune is for much larger injectors, not sure it will want to start with stockers?
GSX - 571whp/490wtq
Sienna
Old 07-21-2013   #17
Speedfreak
Drives: four tires
The thread is now a Want To Buy thread. Swapped in my cousins pte 1000's and the car started.
Asked Shane for a quote on some injectors, otherwise let me know if anyone has anything trusted in the 1200cc+ range.
GSX - 571whp/490wtq
Sienna
