Old 08-13-2013   #1
blesi660r
blesi660r's Avatar
cleaning a block Q.
I finally picked up my short block this past weekend and I have a few Q on how I should go about cleaning it out.
This block has been on a stand for over 3 years mind you and it is complete.
I really dont have the option to hot tank it... so should I just drop the pan and go to town with some carb cleaner.. how should I go about cleaning out the cylinders? It did have a head on it but no plugs in the head so there is a little grime and random dirt in there also.
Any tips.
Just couldn't stay away.
Old 08-13-2013   #2
Re: cleaning a block Q.
I would just use a rag with some brake cleaner to wipe out the cylinders and any miscellaneous grime, then put some fresh oil on the cylinder walls. There's not a lot to to do in that situation, I'd just change the oil after 20 miles, like a new build, and you should be all good.
Old 08-13-2013   #3
blesi660r
blesi660r's Avatar
That's what I was planning on doing just wanted a second opinion. Thanks dude.
Old 08-14-2013   #4
blesi660r
blesi660r's Avatar
Has anyone found a high temp spray paint that actually sticks to the block .
Old 08-16-2013   #5
blesi660r
blesi660r's Avatar
block paint anyone...
Old 08-17-2013   #6
I just plan on using some Rustoleum engine enamel. I've also thought about using por15 engine enamel, it looks to be ~$25/pint though.
Old 08-17-2013   #7
Tachyon
Tachyon's Avatar
Drives: Icarus
I've used Rustoleum engine enamel with great success several times. I typically put a wire wheel on the end of a drill and clean the outside very well.
-Sebastian Vettel
Old 08-17-2013   #8
blesi660r
blesi660r's Avatar
Good idea with the wire wheel! Stupid simple things like that I forget to do . Thanks for the info guys.
Old 08-17-2013   #9
I used a can of aircraft paint stripper, then I'm going to pressure wash it to blast the paint off before I get it hot tanked. Probably overkill, but its only costing me an $8 can of paint stripper.
Old 08-18-2013   #10
blesi660r
blesi660r's Avatar
That's whats sux as im not hot tanking mine so we will see how well the paint holds
