Old 08-10-2013   #1
awd laser
awd laser's Avatar
Drives: 93 TSI
6 bolt swap 97 tsi
Just picked up this 97 tsi shell from South Dakota last night. The car is awd 5speed and has 101k miles. This car is pretty clean with almost no rust. It came without a motor, tranny, intercooler and exhaust. It only came with dsmlink v3, eprom ecu and a walboro 255.
The plan is to swap the 6 bolt from my 92 laser and run it stock until I gather all of the equipment to build it next spring. The plan is an oem build with 2g pistons and an evo3 turbo. This car will be my daily up at UMD until I figure out what I want to do.
I will keep you guys updated on the 6 bolt swap in the mean time. So far I still need to find an exhaust, tranny and xfercase, TPS, ps pump and bracket, a/c bracket and a front passenger axle. I will start tearing apart the laser tomorrow morning and post pics as I go. Enjoy!
Old 08-10-2013   #2
awd laser
awd laser's Avatar
Drives: 93 TSI
Re: 6 bolt swap 97 tsi
Here's more pics
Old 08-10-2013   #3
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Looks clean.
BW8776, e-85
Old 08-10-2013   #4
bigboostingst
bigboostingst's Avatar
Drives: AWD Spyder
Awesome! I went and checked this car out a few weeks ago. Pretty clean. I went to UMD too!
Old 08-10-2013   #5
Fejery4491
Fejery4491's Avatar
Drives: 97 Mitsubishi Eclipse GSX
I love me a clean 2gb talon. Looking good!
Fejery4491 is offline   Reply With Quote
Old 08-10-2013   #6
awd laser
awd laser's Avatar
Drives: 93 TSI
Thanks guys! If you guys have any of the parts I need PM me with a price.
Old 08-10-2013   #7
awd laser
awd laser's Avatar
Drives: 93 TSI
Nice! What was your major?
Old 08-12-2013   #8
97gsexx
97gsexx's Avatar
Drives: 97 talon
Clean talon, good luck with the swap! I pm'd you about some parts you need.
97 gsx (sold)
97 talon tsi awd 🐼
Old 09-19-2013   #9
awd laser
awd laser's Avatar
Drives: 93 TSI
Update on the car. Goodbye laser, 6 bolt went in a few weeks ago. Just got her started Monday. Hopefully get the exhaust done and reset the link settings for stock injectors.
Only problem right now is that I can't connect to my ecu. A window always pops up and says that it can't find the port. Any advice?
ID:	13974   Click image for larger version
ID:	13975   Click image for larger version
ID:	13977   Click image for larger version
Old 09-19-2013   #10
awd laser
awd laser's Avatar
Drives: 93 TSI
Another thing. I went to hook up the vacuum lines for the fpr and the intake manifold and cant seem to find the fpr solenoid. Do I need one in order for the car to run good? Or will it cause bad idling/airfuel ratios?
Old 09-19-2013   #11
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Holy clean 2gb!
Old 09-20-2013   #12
awd laser
awd laser's Avatar
Drives: 93 TSI
Thanks! Haven't gotten her first wash yet, more pics to come!
Old 09-20-2013   #13
mark4g63t
mark4g63t's Avatar
Try wiggling/ pushing all the connectors (especially the obdII) together. Sometimes they come apart, and I don't believe you need the fps. *but don't take my word on that*
BW8776, e-85
Old 09-20-2013   #14
awd laser
awd laser's Avatar
Drives: 93 TSI
I already did, I get a quick flash from the link cable right when I plug it in but then I'll try to connect to the ECU and it says that it can't find COM1 or something.
Yeah I did a little research and talked to a few guys. They said I can just run a vacuum line from the intake manifold to the FPR.
Old 09-20-2013   #15
mark4g63t
mark4g63t's Avatar
Do you have more than one usb port on your computer?
BW8776, e-85
Old 09-20-2013   #16
awd laser
awd laser's Avatar
Drives: 93 TSI
Yup it's a mac with 2 3.0 usb ports. I have windows 7 partitioned to another part of my hard drive which is what I run link with. I've been able to use regular USB's just fine on both sides of my computer.
Old 09-20-2013   #17
mark4g63t
mark4g63t's Avatar
Did you download it to a specific usb port?
BW8776, e-85
Old 09-20-2013   #18
idk about 2g's but on a 1g you can year out that fp solenoid without even getting a CEL. I think on a 2g you can do it but you have to check the emissions box in link or something.
Old 09-20-2013   #19
awd laser
awd laser's Avatar
Drives: 93 TSI
Were you suppose to download it to a specific one? I thought it didn't matter which USB port it was plugged into as long as it got downloaded into the computer?
Goodhart yeah I checked around and it seems like I should be safe running without the solenoid as long as I run a vacuum line to the fpr from the intake mani.
Old 09-20-2013   #20
mark4g63t
mark4g63t's Avatar
Mine would only work on the port closer to the memory card slot ( macbook pro) or it would freeze after connecting. Is the most recent version downloaded from here http://www.ecmtuning.com/downloads.p...c23rfg5rvl6e47
BW8776, e-85
