Old 04-13-2010   #2
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: E85 Blends
Good info! I'm moving to arizona or florida below 29 latitude!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 04-13-2010   #3
LaunchHard
LaunchHard's Avatar
Re: E85 Blends
Can anyone tell me if the good blend is out yet, and where to find it?? Im trying to get my car tuned on monday, but i would like to do it on the good blend. Unless it doesnt make a difference??
Old 04-14-2010   #4
Re: E85 Blends
I'm guessing it's still e70 here, but that's all I've ever been tuned on, it's still awesome. I wouldn't worry about getting a specific e85 tune vs e70, at least for a daily driver.
Old 04-14-2010   #5
blackrosenova400
blackrosenova400's Avatar
Re: E85 Blends
The easiest way to do it is to tune it with the best blend, then let it run rich when it goes back to the crappy blend.
20g Mafia
Old 04-14-2010   #6
Re: E85 Blends
It'll be more prone to knock with the winter blend though if you get it tuned on the summer blend. It seems like the few gas stations I've asked don't always follow a calendar or a timeline. If they don't sell a ton of e85 in the summer/spring, they aren't going to swap it out/order more until most of its gone. I would assume the same goes for winter blend.
Old 04-14-2010   #7
Re: E85 Blends
You might knock on the worse blend though, it you are tuned to the edge on the best blend. It runs richer, because they are adding in more crap gas, so it's going to be lower octane than the good blend.
Most of the stations around here were E70 until the end of May, I can test the ethanol content, if you bring in some samples.
Old 04-14-2010   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: E85 Blends
Here is another good chart, at the bottom of the page.
http://jeffgst.com/e85global.html
-1990 Mitsubishi Cyborg 4WD-
Old 04-14-2010   #9
CarPsyco84
CarPsyco84's Avatar
Re: E85 Blends
Someone was telling me about some place south of town that sells Actual E85, E98 and other race fuels, by the barrel too. Might be worth checking into if your looking for it, Otherwise unless your running over 30psi I doubt you would have knock issues even with E70 anywase.
-When in doubt, Moar RPM.
Old 04-14-2010   #10
Re: E85 Blends
I was going to look into it, but I don't have a place to keep it. My friend might though.
Please let us know if you find out where. I figured some co-op.
Old 04-14-2010   #11
CarPsyco84
CarPsyco84's Avatar
Re: E85 Blends
Yeah, if only I could remember who was telling me about it...
Old 05-04-2012   #13
Re: E85 Blends
60%? Shit, I better write to the state about this, the pumps say minimum 70% ethanol!
I should have found out what % alcohol I was running when tuned in April.
Old 05-04-2012   #14
Re: E85 Blends
I used one of those the whole time I ran e85. I've been hearing of lots of people reading super low as well...
Old 05-04-2012   #15
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
Re: E85 Blends
Man that's garbage. At what percent does E85 because equivalent or similar to 93 octane pump gas?
Just some corn and a MBC. Try it. You'll be amazed.
Nartanian is offline   Reply With Quote
Old 05-04-2012   #16
Re: E85 Blends
It should have been 70% just about everywhere in MN. When it switches to 80-85% the car will lean out 10-12%.
Old 05-04-2012   #17
Re: E85 Blends
Originally Posted by blackrosenova400 View Post
Ive been testing ethanol content with this,
http://www.summitracing.com/parts/QFT-36-E85/
Anybody else test e85 ethanol content? Ive been reading 60% everywhere with this tool!
I tested the Kwik Trip in Shakopee and it is 62% roughly right now.
I'll have to get a clean sample of E98 from John to validate the tester.
Old 05-04-2012   #18
Re: E85 Blends
If anyone wants to bring some samples to the dyno day, I have a digital tester we can test them with.
Old 05-04-2012   #19
Revobasher
Revobasher's Avatar
Drives: 14 Evo X GSR
Re: E85 Blends
I will bring a sample.. I need to get my Zentronix ECA hooked up!
2014 CB Evo X GSR - 323/324 @ 26lbs (Mustang Dyno)
2012 IS250 F Sport - TOTALLED
2006 Evo IX MR - ​SOLD
Revobasher is offline   Reply With Quote
Old 05-04-2012   #20
Re: E85 Blends
FFS 62%?
