Old 03-25-2015   #1
plow420
plow420's Avatar
Drives: 96 eclipse gsx
un cut 6 bolt crank
Looking for a virgin crank 6 bolt.
plow420 is offline   Reply With Quote
Old 03-25-2015   #2
blesi660r
blesi660r's Avatar
Re: un cut 6 bolt crank
I've got one pm me
Just couldn't stay away.
Old 04-10-2015   #3
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Why does everyone want virgin cranks? what is wrong with running oversized bearings? me no get.
Style's automotive engineer
Old 04-10-2015   #4
plow420
plow420's Avatar
DSM cranks have a hardened layer and that's why the FSM says they are not serviceable. Its a big debate, many shops also don't recommend it.
Old 04-10-2015   #5
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
^ what he said, the re treating of the crank isnt cheap either.
Old 04-10-2015   #6
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Ive got one im sure might need a polish but ill check when i get home from work
Tyler
2011 Subaru Sti 11.0 @135mph
Old 04-10-2015   #7
s1ngletracker
Drives: A BMW
Interesting, I was not aware of that. Thank you!
Old 04-10-2015   #8
It's the nitride coating. Cheaper to find a fresh on than have it re-nitrided.
Old 04-10-2015   #9
s1ngletracker
Drives: A BMW
gotcha! Makes sense that they are case hardened, that would do a lot for wear resistance.
Old 04-10-2015   #10
plow420
plow420's Avatar
I called crankshaft supply today and to service my crank, it will cost $366 plus me shipping and shipping back.
That includes filling the thrust bearing on crank, cutting and polishing the mains, also the nitrate coating. The nitrate coating is $168 alone.
The only reason why i might send them the crank is that it was balanced, I don't know if it will still be balanced after they work on it.
And i am still looking for a good used 6-bolt crankshaft.
Old 04-10-2015   #11
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
$366 isn't bad when comparing to the alternative. Eagle junk for $500ish or Manley for 6. Crankshaft supply is the beesneez around here. They don't carry any 4g cranks down there? Would almost think they would.
Good luck on the decision.
Old 04-10-2015   #12
plow420
plow420's Avatar
Crankshaft Supply don't have any stock of 6 bolt cranks. I wish i knew of them sooner. I've trashed 3 cranks because they needed to be cut.
I also have a set of acl tri metals sitting in my garage, I'm thinking about going to aluminum. I haven't had the best luck with the tri metals.
Anyone with experience with aluminum bearings around 500 whp.
Old 04-10-2015   #13
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
You can cut 7 bolt cranks .010 and be fine, they are induction hardened and the hardening layer is .025-.030 deep, a 6 bolt crank is nitrided and that only goes .010-.015 deep so a basic .010 cut could remove the hardening off the journal.
punxnotdead185 is offline   Reply With Quote
