Old 04-30-2017   #1
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
1990 GSX for sale
I am selling my 90 GSX. This was my race car project from 2004-20013 This would be the perfect project car for someone looking to get into drag racing. Here is the list of parts that are in the car right now. Many extras also included in the purchase of the vehicle. $8,500
-Precision 600HP Front mount intercooler 31-1/2"L X 8"H X 3-1/2"D (2-3/4” inlet & outlet)
-50 mm Tial Blow off valve (old style) RED
-75 MM accufab throttle body
-Magnus sheet metal intake manifold
-DNP Exhaust Manifold
-FP3065 Turbo Oil cooled,DSM Exhaust manifold flange. V-band clamp downpipe, V-band -wastegate flange
-44 MM Tial wastegate
-GM Maf translator with 3.5” GM MAF
-Custom 3” turbo back exhaust
-Fuel injector clinic fuel rail -8 feed -6 return
-Bosch 044 fuel pump
-1650 BlueMAX injectors Low impedance
-Aeromotive A1000 Fuel pressure regulator
-Auto meter Mechanical fuel pressure gauge
-JM Fab front bumper support
-Moshimoto aluminium Radiator 12” & 10” fans
-Solid Motor Mounts
-E-prom ECU w/DSM link V2
-Hallman Evolution RX Boost controller
-Stock Valve cover (no cracks!)
-Kiggly racing beehive valve springs
-Brian crower 280 Cams
-AEM adjustable cam gears
-Revised lifters
-1mm oversized Supertech Valves
-Bronze valve guides
-Maperformance Ultimate duty rods
Wiseco piston .20 over HD wrist pins
-Stock 6 bolt crank untouched
-Balance shaft removal kit
-Kiggly racing 6 bolt main girdle
-Fluidampr harmonic balancer
-Stage 4 shep trans welded center diff (New) less than 300 miles
-Clutch Master Twin disk
-Un-abused transfer case
-Stock drive shaft with new u-joints
-4 bolt rear end
-2G front brake upgrade
-D2 coil overs (purple)
-Battery relocated in trunk
-8 Point Roll cage
-Top Speed bucket seats for pair with 4 point harnesses both driver and passenger
ID:	16496   Click image for larger version
ID:	16500   Click image for larger version
ID:	16498   Click image for larger version
ID:	16499   Click image for larger version
ID:	16503   Click image for larger version
ID:	16504   Click image for larger version
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
