Old 11-13-2004   #1
93talon
Send a message via ICQ to 93talon
maf question
i have been hearing alot about a maf mod im guessing dats a mass airflow sensor? if so what is the mod ive been hearing about ive heard about removing the lower honeycomb and something about putting in a gm chip or adapter or something could someone tell me about this it would be much appretiated i have a 1.8 sohc talon and just turned 16 and eager for mods thanks in advance -1
93talon is offline   Reply With Quote
Old 11-13-2004   #2
LightningGSX
Hellbound
People pull out the honeycombs in attempt to lean out the A/F a little.The honeycombs straighten out the airflow, when removed, it harder for the MAF to meter airflow so it lets a little unmetered air through.In my opinion, this mod is stupid, and won't do you much good(especially on a NT 1.8)
The GM thing, is a adapter called the MAF translator, which allows you to run a GM MAF, which are usually larger and less restrictive.Again this won't do you much good either, and it costs $199 plus the price of a GM MAF ($25-$125)
-Nulli Secundus-
Old 11-13-2004   #3
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
So in not so many words, your fucked with the 1.8L as far as performance goes. Getting some better flowing exhaust and a cold air intake would be the only fairly cheaper things you could do to make it faster.
But hell Alan thinks they are fast, he told me today that he beat a Geo on the freeway earlier today.
CRAIG
Old 11-14-2004   #4
Raptor
ConArtist
Raptor's Avatar
CRAIG
The geo was parked
If you are dead set on making any power with the 1.8, you should look into porting and cams as well. There are plenty of mods you can do, they all cost more than the engine is going to be worth and likely you will never be happy with it but it is your right to build it.
Old 11-14-2004   #5
Nitrous.
Old 11-14-2004   #6
93talon
thanks you guys yea i know the 1.8 aint much but its all i got for awhile atleast im thinkin of doin a dohc turbo swap but jus gotta get up some $
Old 11-14-2004   #7
HondaKiller
HondaKiller's Avatar
A 2.0 Turbo swap and you would still be FWD.
I say keep the 1.8 as a winter beater and find a GSX, or you could always not worry about making power and mod it for straight show, which is what N/T owners I've seen tend to do.
HondaKiller is offline   Reply With Quote
Old 11-14-2004   #8
LightningGSX
Hellbound
I wouldn't even bother, drive the 1.8 until your money situation allows you to buy a turbo DSM.
-Nulli Secundus-
Old 11-14-2004   #9
It will probably cost more to acquire all the parts needed to do a 2.0 Turbo swap then to just buy a turbo DSM.
