Old 10-23-2004   #1
joem
Drives: 1991 Talon awd auto
http://www.dsmstyle.com/forum/index.php?showtopic=5236
Why did this happen? My old motor did the same thing remember Mike
the first block that was in my talon.
Plus will it brake the new one he puts in.
joe
Old 10-23-2004   #2
Raptor
ConArtist
Raptor's Avatar
Not sure why this one broke. He mentioned the old squirter was very loose, it may have worked it's way over and been knocked off somehow. It didn't show obvious signs of impact from what I saw, but that would be my guess. Beyond that, maybe someone else has other theories they would contribute.
Joe, your definately was knocked off, it had more obvious damage. These things are only torqued at 25 ft/lbs so it wouldn't take that much to have one end up working it's way loose. I use a very small amount (so it can't end up in the valve) of thread lock on them to help prevent that from happening as well as new crush washers. Never had one come loose on any I have built.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 10-23-2004   #3
Quick update: put in a new squirter, washers, and a drop of threadlock like mike said, and it seems to run fine, for now. No road time yet, but I think this'll do the trick, at least for a while.
-scheides
ps--special thanks to QPR for the great info & support!
Old 10-23-2004   #4
Raptor
ConArtist
Raptor's Avatar
Your welcome Chris, glad it worked out
651-488-7774
Old 10-23-2004   #5
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
damn mike, how many more lives can you save in 24 hours?? lol
- Josh L.P.
Old 10-24-2004   #6
Well, got everything back together today, took it for a spin, seems to behave just as though nothing happened. Idles normally, revs fine, boosts fine, makes plenty of power.
In short...YEA! I'll post to this thread if anything comes up. This'll hopefully get me in gear to build a motor...anyone have a 4gcs block lying around?
Thanks again to QPR, who helped me narrowly avoid spending thousands of dollars with them...wait, what kind of company is this, anyways?
-scheides
'94 TSi AWD
Old 10-25-2004   #7
Raptor
ConArtist
Raptor's Avatar
One of two things Chris, either we are extremely ethical or not all that bright, could be both. :bounce:
651-488-7774
Old 10-25-2004   #8
Enes
Enes's Avatar
i say its more like AND..
-e
Old 11-13-2004   #9
acidrumz
broken oil squirtor
hey, i think i may know why your oil squirtor or anyone's oil squitor (is that miss-spelled?) breaks or keeps on breaking on replacements.
well the last time i overhauled two 4g63s motor, i found both of the motors had that problem. but upon careful checking and measurements, i laid a straight metal ruler across all the pistons top on the block. to a surprise i found that one of the pistons, (piston 1 and 4 or 2 and 3) when cranked, one of the piston did not lined up tdc to the top of the block. and from the broken squirtor, that piston was low. i believe it was shorter like 1/8th of a inch. maybe even less like 1/16th of a inch. can't remember which. but it is slightly small, but the nake eye can notice it.
that is serious problem. the lead cause i think would be in the connecting rod bearings and even the mains. and worst the crank journals.
that was found on both motors. i didn't finish rebuilting the motor because the owner decided to get another used motor.
but thats my input on that. hopes that helps.
good luck.
Old 11-13-2004   #10
LightningGSX
Hellbound
So you're saying the piston was physically contacting the squirter?
-Nulli Secundus-
Old 11-16-2004   #11
acidrumz
my guess is somehow the bottom of the piston made contact with the squirters.
that is the only rotating/moving part that is closest to the squirters.
i didn't get to do a full inspection except for what i've mention above.
later.
Old 11-14-2004   #12
Bearings aren't 1/8" thick, so it's not those. Sounds like a bent rod to me.
Old 11-14-2004   #13
Raptor
ConArtist
Raptor's Avatar
I would have to say bent rod as well to get that much of a difference. We just worked on a car with the #1 rod bearing pretty much completely gone and it still had the squirter in place. I can't imagine a rod bearing being in worse condition and the rod still on the crank like this one was.
Old 11-14-2004   #14
joem
Mine hit it. Broke it right off.
joe
Old 11-16-2004   #15
Yea, mine hit it as well. Broken clean off. Mine happened about 5-10 seconds after starting the car, so I wonder what that could have to do with it. When did yours brake off Joe? I wonder what would've happened if it happened at a cruise. Can you say kabluie!?
One time I was riding my FZR through the tunnels on 94 downtown. I was in a tuck at about 85 and one of the pieces that holds you bolt the valvecover to decided to break off and go dancing with my lifters, valves, and cam. Again, can you say Kabluie!? I coasted all the way to the hwy 55 exit.
-scheides
Old 11-16-2004   #16
joem
Mine was broke when i bought the car. It had blowen the timing belt right before that
then i bought it as a shell basically.
joe
Old 11-16-2004   #17
The crank also gets very close; the squirter I replaced my broken one with from was from a 6bolt, and it was shaped ever-so-slightly different from the other ones. I didn't notice it until I put it in and rotated the crank...part of it *ever* so slightly scraped against it, and when it was past, it left some scrape marks on it. I carefully bent it into the right shape, and re-installed.
PS prolly 1000 miles or so since this happened, and no problems yet!
Old 11-17-2004   #18
They break all the time, as long as they don't damage anything on the way out, they just sit on the bottom of your oil pan and lower your oil pressure a bit.
Old 11-17-2004   #19
The part that breaks off is only brazed to the banjo fitting, so to much heat, vibration, and/or contact from the crank would cause it to fall off easy enough. And unless the bolt falls out it will not lower your oil pressure, the check valve is in the bolt itself.
Old 11-17-2004   #20
Raptor
ConArtist
Raptor's Avatar
I agree with john except that brazing and welding are two different things also there are 2 o's in "too" when expressing excessive quantity.
