Old 01-21-2005   #1
4G64 specs
Can anyone give me some info on for a 6 bolt 4G64 from a 92 eagle summit? I need bore (should be 87mm right?), and the bearing specs. A machine shop would know that crap right? I'm gonna magnaflux the block first before I have a machine shop do anything. I don't know crap about this stuff, but I'm learning. Also, should this motor be built loose? I hear thats a good idea for forced induction engines... How loose should it be exacly? .001" over?
Old 01-21-2005   #2
Re: 4G64 specs
.001" over on what exactly? The stock bore on the 2.4ls is 86.5mm.
Old 01-21-2005   #3
Raptor
ConArtist
Raptor's Avatar
Re: 4G64 specs
If you are just having it machined, specify to the shop how far over you want the bore, and how tight you want the piston wall clearance (different based on piston manuf) They will have the rest of the specs they need to machine it. As far as building the motor loose, depends on what you want to do with it. All out drag, sure build it looser, DD you don't want loose, everything wears a lot faster and is much louder (piston slap etc) Your question of how loose doesn't work, depends on what your referring too, bearing clearances, piston clearances, ring gap etc.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 01-21-2005   #4
Re: 4G64 specs
ahhh thanks for the info, and forget about the "how loose." I went to Kath's machine shop..the guy gave me prices but he was kind of a dick...maybe because I said it was for a Mitsubishi 4 cylinder... or most likely because i dont know what im talking about haha.
Old 01-21-2005   #5
LightningGSX
Hellbound
Re: 4G64 specs
They're always dicks about everything, unless your an old guy with a V8
-Nulli Secundus-
Old 01-21-2005   #6
jasonlee
Guest
Tournaments Won: 6
Posts: n/a
Re: 4G64 specs
:werd: Thats how everybody is around here!
J
Old 01-22-2005   #7
Re: 4G64 specs
thats kinda why I want to make a Honda fast... it would actually bother some of those old farts with v8s...and that sounds like fun.
