Old 04-19-2005   #1
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Thumbs up Shift from AWD to FWD.
Japanese Domestic Market (JDM) Galants were available with a switchable tranny/transfer case combo, allowing you to switch to FWD simply by removing a bolt and bracket from the tranny and transfer case. Removing the bolt from the tranny allows the plunger in the case to extend, locking the center diff down. Removing the bolt from the transfer case allows the plunger to retract, unlocking the shaft, allowing the transfer case to freewheel. I need to find one of them!!
Take her to the limit!
Old 04-19-2005   #2
npaulseth
Re: Shift from AWD to FWD.
This is new info?
Old 04-19-2005   #3
You can find one on eBay every once in a while, but I don't know of anybody using it.
Old 04-19-2005   #4
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Not really new info.
just FYI for who ever.
Old 04-19-2005   #5
Never heard of that, wow that would be nice. Have to keep my eye out.
Old 04-19-2005   #6
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
OLD! If your going for tons of power, I have heard these are weaker.
Old 04-19-2005   #7
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
I'm not sure if its weaker, I would have to look inside of one. but I would be putting ont in a stock talon AWD for hopes of better MPG.
Old 04-19-2005   #8
TurboDomestics
TurboDomestics's Avatar
new to me, now wouldnt it be nice if you could do that inside the car or while moving, you could get the AWD launch and then switch it off once your moving so you dont get all the parasitic loses in hp.
I dont know, if i stated thaqt as accuratly as possible, but im sure some one understands what im saying
TurboDomestics is offline   Reply With Quote
Old 04-19-2005   #9
slowbubblecar
slowbubblecar's Avatar
John has one that he will be putting into his talon. After he gets mike to weld a vc, all he has to do is drop a bolt to dyno from awd to fwd.
Old 04-19-2005   #10
The output shaft going to the driveshaft on the switchable JDM transfer cases have been known to snap.
Old 04-20-2005   #11
So is it just a transfer case that is different or is the "bolt" in the transmission? What parts would you need to swap out to make it work with a 1G.
Does it match up to the splines on our trannys here? I have no idea how it works... as Ive never heard of this before.
I assume its weak basically like having a 3bolt versus a 4bolt rear end?
Old 04-20-2005   #12
Jed
The RTFVfaq Guy
Jed's Avatar
Doesn't anybody look at vfaq.com anymore?
http://www.vfaq.com/mods/Tranny-switchable.html
They are all 22 spline.
"We are the music makers, and we are the dreamers of dreams."
Jed is offline   Reply With Quote
Old 04-20-2005   #13
john
Business as usual
john's Avatar
They are exactly the same as far as bolting them in but can be switched. I was told that mine was modified to be switchable, it was not a JDM part. I am not sure though. I got it from Joem. What is a ton of HP or enough to break the imput shaft?
97 Viper GTS
Old 04-20-2005   #14
A 20G.
Old 04-20-2005   #15
john
Business as usual
john's Avatar
Originally Posted by ecoli
A 20G.
We will see how it lasts then I should be in the 20g power range... I have a backup t-case just in case.
97 Viper GTS
Old 04-20-2005   #16
That transfer case actually is the JDM one. It came as a switchable, it was not modified.
Old 04-20-2005   #17
john
Business as usual
john's Avatar
Oh, I thought he said he looked up the parts and converted it or something. I must have heard him wrong then.
97 Viper GTS
