Old 06-23-2005   #1
john
Business as usual
john's Avatar
car overheats
The car has a new waterpump already installed about 30 miles ago, has plenty of coolant, a new thermostat as of yesterday and a slimline fan that is working. The car drives perfectly fine, but sometimes the temp guage randomly goes higher. It can be right in the middle, jump up to the higher mark on the guage and out of nowhere just fall back to normal. It doesn't get to the red on the guage, but it is close to it. The idiot lights turn on (battery, coolant) as it is hotter. I don't think another fan would really help as it was driven at 9:30 last night and it wasn't too hot. Coolant isn't leaking either and is full. Any ideas?
97 Viper GTS
Old 06-23-2005   #2
blageo23
blageo23's Avatar
Re: car overheats
Im not the smartest guy but maybe the sensor is messed up. Have you checked the connection maybe its wack. Like I said I dont know much but maybe this will put a thought in a some who know exactly what they are talking abouts head.
Mike
Old 06-23-2005   #3
john
Business as usual
john's Avatar
Re: car overheats
It is connected right. I wouldn't even know how to check if the sensor is messed up though.
97 Viper GTS
Old 06-23-2005   #4
TheBlizzard
TheBlizzard's Avatar
Re: car overheats
Check your belt tension to make sure that its not slipping. Does the car have a front mount of anything obstructing the flow of air to the intercooler. And I know you said the fan is working but how do you have it wired in? Is it hard wired with a toggle switch or into your existing wiring?
Old 06-23-2005   #5
Re: car overheats
Could be a large air bubble trapped in the system.
Old 06-23-2005   #6
Enes
Enes's Avatar
Re: car overheats
i was always currious how would you go about removing large air bubles out of the cooling systems?
Old 06-23-2005   #7
TheBlizzard
Re: car overheats
Burp it.
Old 06-23-2005   #8
john
Business as usual
john's Avatar
Re: car overheats
buuuuuuuurrrrrppppp. The bubbles are out now. Does letting it run with the thermostat housing cap off get bubbles out? The car has a big greddy FMIC and the fan is wired to the original harness. The high and low were both wired into it. What belt tension should be checked? I know when I start driving it, one of the belts squeels a little when I shift into gear. Do you think the belt might be slipping slowing the waterpump down?
thanks
97 Viper GTS
Old 06-23-2005   #9
Re: car overheats
Use a logger of some sort and monitor the temp. If it's erratic that would mean the sensor is bad.
Check the tension of the only belt that's on the water pump pulley...
Old 06-23-2005   #10
CDeutsch
CDeutsch's Avatar
Re: car overheats
Are you running the AC? That will also cause the temp to rise.
06 Evo IX RS
99 Miata
Old 06-23-2005   #11
TheBlizzard
Re: car overheats
Yeah thats the belt I was talking about, who knows maybe when a load is put on your alternator it will slip causing the water pump not to function properly? Erratic temps does not always mean its a sensor. I had pretty erratic temperatures in my 2G after I put my Apexi Skyline FMIC in it. The temp would jump up past half and then cool down on its own. I just figured it was because of limited airflow that the radiator was seeing because of it. Then when the fan would kick on then it would go back down to normal.
Old 06-23-2005   #12
john
Business as usual
john's Avatar
Re: car overheats
The ac was removed and the car keeps heated when the fan is going. I let it sit a few minutes to see if it would get to the red, but it just stays at the high mark. I will try to see if I can find the pocketlogger when I get home from work tonight. I cant use mt dsmlink right now.
Thanks
97 Viper GTS
Old 06-23-2005   #13
Re: car overheats
I'm having the same issue. I hope more peaple chime in about your issue so I can fix my car too! (Not trying to steal thread haha, I'm just along for the ride)
Old 06-23-2005   #14
john
Business as usual
john's Avatar
Re: car overheats
I guess James posted all of this under my name... I tried letting air bubbles out by running the car with the cap off for 1-2 mins when the gauge would fly. The fan is working (on) when the car is getting hot. FYI, there are two belts that run off the water pump. One that runs to PS and another that runs the alternator and crank. I will check the tension for him.
97 Viper GTS
Old 06-23-2005   #15
Re: car overheats
We bleed the system by letting the car for a while with a big funnel thing full of coolant mix attached to where the radiator cap goes. What is your coolant mixture like? You should be 70% water/30% coolant at the min with this weather. You could go even more with the water percent. Don't run pure water though on a street car, it can ruin the water pump due to a lack of lubrication. Your radiator could be bad too, make sure there aren't any cooler spots on it.
Old 06-23-2005   #16
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: car overheats
I have a special funnel that I use to get the air out.
Is it a NAPA water pump?
How is your coolant cap, It could be leaking into the overfill the system and not holding presser.
Is your timing correct?
Try switching the cooling fan relay with a different one.
Try a different thermostat.
Take her to the limit!
Old 06-23-2005   #17
john
Business as usual
john's Avatar
Re: car overheats
The fan works. It is a napa pump I believe. Timing is set fine. It is a new thermostat. Radiator cap holds pressure. I would guess his mix is close to 50/50, not sure though. He put it in but it was fine... How long to bleed the system??? I do not want the car to overheat while trying.
97 Viper GTS
Old 06-23-2005   #18
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: car overheats
New does not mean good. New stuff goes to shit all the time. Especially NAPA stuff in my experience.
Old 06-23-2005   #19
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: car overheats
How do you know the cap is holding pressure? do you have the overfill hose off?
What happened that started the car overheating in other words, what did you do to the car last before it started to over heat off and on. Was the car overheating before the new stuff?
Old 06-23-2005   #20
john
Business as usual
john's Avatar
Re: car overheats
I assume it is holding pressure because it isn't losing any coolant what so ever. The overflow hose is connected. The waterpump is a rebuilt stock one from bumper to bumper, not one of the really generic ones. The thermostat we got yesterday is from there also. The other one I pulled out looked different. It had the cylinder thing going down with a spring on it. The new one had the same top part but it also had a bottom part that looked the same as the top that was a little thinner. It was a lot longer than the one that was in there and thepart that sitcks out farther can be pushed in and out. The first one was solid. I was thinking it might have came off the first one, but it looked like it didn't have it. The car didn't overheat until I did the 6 bolt swap. I assume timing it good because Mike did it and base timing was set correctly. I will try another relay.
Thanks for all the help so far.
This is James again under Carlos's name.
97 Viper GTS
