Old 08-05-2005   #1
StealthGST
StealthGST's Avatar
Send a message via AIM to StealthGST Send a message via MSN to StealthGST
Sick of random misfire, too cheap for dsmlink
Can I just buy a pocketlogger cable (I have a palm) and reset the CELs with that? That would fix my problem right
I really want DSMlink but I dont have the money for it
1997 Converted 1995 Mitsubishi Eclipse GS-T w/ 6 bolt
StealthGST is offline   Reply With Quote
Old 08-05-2005   #2
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: Sick of random misfire, too cheap for dsmlink
Reseting the CEL isn't going to cure an existing problem. All your going to do is get rid of the light and it will come back eventually.
Also give some more info about the car and what the hell you are talking about. What you are saying is pretty vague.
Old 08-05-2005   #3
StealthGST
StealthGST's Avatar
It's a 1995 GS-T with a 6 Bolt Swap, 14B, 660CC, Walbro 255LPH, Aeromotive AFPR, ACT2100. Swap done by QPR, Dyno Tuned at Elite Autosport
The car works 100% great until it throws the random misfire code, then all hell breaks loose (people with random misfire problem know what I mean) then I have to go get the codes reset with a code reader.
All I really want to know here is will the pocketlogger be able to reset the ECU codes until I can afford a DSM Link setup
Old 08-05-2005   #4
Should have done the RRE version of the 6-bolt into a 2G swap instead of the Magnus way, if you knew you weren't going to get a DSMLink or standalone.
You could buy the Pocketlogger and keep reseting the CEL, if it doesn't happen often enough to drive you crazy. But I guess if it didn't happen constantly, then you would just reset the ECU instead. You might be able to get something cheaper also, like this one: http://cgi.ebay.com/ebaymotors/OBDII...65718731QQrdZ1
Old 08-05-2005   #5
StealthGST
StealthGST's Avatar
I didnt do the swap, Mike did it. And I honestly didnt know it was an issue, the way it was described to me I wasn't gonna have any problems.
I'm at work and they block ebay but I'll check it out when I get home.
Old 08-05-2005   #6
Doesn't Lightning have something to take care of this issue?
Old 08-05-2005   #7
StealthGST
StealthGST's Avatar
I don't think he ever settled on any true fix for it
Also is anyone here selling a pocketlogger setup?
