Old 10-26-2005   #1
BOVADDICT
is in debt neck deep
loud ticking
After turning my boost controller the wrong way running just a bit too much boost for about a minute drive total, I immediately turned the car off, turned my boost to about stock, and turned the car back on to realize a loud ticking around the intake manifold/top of valve cover. It drove all the way home but still ticked.
95tsi awd talon, mbc, exhaust, ic piping, stock turbo, stock 7 bolt. everything else shouldnt have anything to do with this.
galant vr-4 #46/1000 16g and supporting
240sx track
BOVADDICT is offline   Reply With Quote
Old 10-27-2005   #2
GREASEMONKEY
GREASEMONKEY's Avatar
Moon Lander Champion!
Drives: 92 TSi
Re: loud ticking
have you checked your oil?
lifter knock?
thats my guess... same thing happened to my buddie but he blew a cam seal.
Old 10-27-2005   #3
BOVADDICT
Re: loud ticking
Checked what about my oil? I had a small ticking before but this shit was loud. I'll see if it is still there when i drive today.
240sx track
Old 10-27-2005   #4
dsm10sec
dsm10sec's Avatar
Send a message via AIM to dsm10sec
Re: loud ticking
Is this ticking louder than my car?
dsm10sec is offline   Reply With Quote
Old 10-27-2005   #5
BOVADDICT
Re: loud ticking
lol dunno. It was pretty bad.
240sx track
Old 10-27-2005   #6
Re: loud ticking
Scary lol. Check your oil, if its low fill it. That could help. Also, lifter tick is extremely common in 2Gs. Its more of a nice tick tick tick tick coming from the valve cover area. My friends car starting tickin one day. It was a really loud ticking coming from the engine, definately not lifter tick. Turns out the engine was fucked. So! Depending on how severe the noise is, if its really bad, scary bad, pull the oil pan and valve cover and look for anything wrong.
Old 10-27-2005   #7
Re: loud ticking
You could pull the valve cover and see if a rocker fell off. Check to see if there is a lot of pressure coming out of the PCV too.
Old 10-27-2005   #8
Re: loud ticking
Check the exhaust, is it smoking, Check shaft play on the turbo.
Old 10-27-2005   #9
BOVADDICT
Re: loud ticking
Turbo shaft play is fine and only smoking cause it's cold as fuck in mn.
I will check the valve cover though cause I need to change that gasket anyway. The ticking was much less sever today but still a louder ticking then normal. Not obnoxious while in the car though so that was nice. Who knows all I know is last night sounding then a sticking a metal rod in a steel fan on high.
240sx track
