Old 11-16-2005   #1
CarPsyco84
CarPsyco84's Avatar
DSM gets 9mpg...
Course it snowed, and it couldn't possably be cause of the way it was driven....
-When in doubt, Moar RPM.
Old 11-16-2005   #2
dsm10sec
dsm10sec's Avatar
Send a message via AIM to dsm10sec
Re: DSM gets 9mpg...
Maybe your fuel pressure regulator is being overrun? I know that mine over runs because I can see it in the knock, when the engine is cold. If I drive around like that the car runs like crap, and I could waste 1/4 of a tank just going 20 miles.
dsm10sec is offline   Reply With Quote
Old 11-17-2005   #3
CarPsyco84
CarPsyco84's Avatar
-Haha, no, the only thing wrong with it was the driver had excessive use of the gas pedal, the car will get 22mpg if im nice to it.... doesn't matter anywase, in less than 100 miles of it being together its now broken AGAIN!!!!
Old 11-17-2005   #4
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
do you guys know how many miles the average dsm gets in a full tank hopefully without heavy throttle?
ლ(ಠ益ಠლ)
Old 11-17-2005   #5
Usually 23-25 on the highway is average for an AWD. Highest I have seen was Nash with 32 mpg on the way to the SO a few years ago.
Old 11-17-2005   #6
I thought Nash averaged more than 32. I thought during 1 tank he was hitting 39 as an average. I could be wrong though.
Old 11-17-2005   #7
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
my dsm got around that when I had the stock ECU
with a eprom and a keydriver stage 3
its in the low 20's and on the highway it is in the mid 30's.
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
Old 11-17-2005   #8
Sorry man, you aren't going to see a 12 mpg difference in gas mileage. The mid 30's must have been on a short fill or your tires are a different size or something.
Old 11-17-2005   #9
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
I check my mpg every single time I fill up and my old FWD would get over 30 anytime it was hwy driven and it would get low 20's in the city. It was in the neighborhood of 10 mpg difference.
The awd got 19 mpg religiously in the city. 23-24 on the hwy.
- Josh L.P.
Old 11-17-2005   #10
Steeltwo
CompUSA Whore
closed loop seems to be the culpurt to the change in gas mileage according to the keydriver guy.
i thought he accidently burned the chip to lean, but after he looked at the log, he said closed loop was causing the increase in mileage.
91 tsi awd
07 Civic Si
06 IS 350
Old 11-17-2005   #11
I don't need a tech 101 lesson. For a DSM to go in closed loop it needs to be at a fairly constant speed, engine RPM and no drastic TPS changes. All DSM's should be running at closed loop on the highway, so there isn't anything special about yours. If you truely are getting mid 30's for gas mileage, you had better have an EGT. You are very lean. On a FWD it is doable because of the taller gearing, lighter weight, and less drivetrain loss.
Old 11-17-2005   #12
My FWD averaged 24 city/hwy and 31 hwy.
Old 11-19-2005   #13
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
I get about 16 MPG city driving. I used to get a little, more even after the EGR block off, and emission removal. I been studying my data logger, and notice that I do not get any O2 readings until about 2-2500rpm. I even tried a new O2 sensor, and that hasn't changed. I'm guessing the voltage supply for the warmer has failed somewhere. Someone told me without O2 readings at idle, its maxing out my fuel trim So once I get a warmer day (40ish) I'm going to go around and try to figure it out. Cause its sucks to have to let your cars stay at idle for so long to warm up.
2004 Dodge SRT4. Bone Stock
2006 Toyota Sienna. Swagger Wagon
SOLD 1992 Plymouth Laser AWD. 13.4 @ 102 Stock tune and turbo.
turbo2086 is offline   Reply With Quote
