Old 11-30-2005   #1
T3/T4 5-bolt setup: looking for opinions
I'm looking at a turbo setup for my car that someone has for sale. It's a T3/T4 60-trim turbo w/ a t3 inlet flange and 5-bolt outlet flange on the turbine housing. He's also got a 5-bolt o2 housing with a full 3" outlet and a tial 38mm wastegate w/ dump tube. The turbine housing also has a T3 to dsm adapter plate to bolt up to a stock manifold.
Any thoughts on this setup? It sounds like a pretty slick deal to me. I was thinking I'd get JET or someone to built me a full 3" downpipe to bolt up to it to finish it off. Or, I could just get the turbo and find a dsm-compatible turbine housing w/ internal wastegate, or...whatever else.
Anyone else running one of these 5-bolt o2 flanges?
Old 12-01-2005   #2
Re: T3/T4 5-bolt setup: looking for opinions
Avoid the 5-bolt housings.
Old 12-01-2005   #3
Any particular reason why? One thing I find odd is, I cannot find much info on them, or anyone else really with a setup like this; is this an old standard or what?
Old 12-01-2005   #4
Yea, it's older, but it was the most common up until just a couple years ago. Find out if it's a Garrett/Turbonetics or Precision 5-bolt housing. The Precision 5-bolt housings are much better, Precision made their own custom 5-bolt version based off the Garrett 4-bolt design, which is much more efficient. The old 5-bolt will still work fine and make power though. With an adapter plate mounting it to the stock DSM manifold and a 60-trim compressor wheel, it isn't going to be the top of the line setup anyways. It should still be capable of over 450whp.
Old 12-01-2005   #5
anyone know how to tell from just looking at it? here's some pics. I know it was from diamondstarmotorsport.com, and they do both turbonetics and pte stuff.
Anyone have a mitsi-flanged turbine housing that would work on this thing?
Old 12-02-2005   #6
Shotgun!
Totenritt
Shotgun!'s Avatar
Can a person swap the old 5-Bolt for the Precision one and have every thing bolt up?
Old 12-01-2005   #7
Looks like one of those 57-trim/60-trim T3/T4 turbos that were sold by places like TurboCalculators for $450.
Old 12-01-2005   #8
really...so, junk then? Or still worth buying? Damn!
Old 12-01-2005   #9
It all depends on price. If it isn't blown and the price is right, then it would be worth buying. It will make power.
Old 12-01-2005   #10
anyone else w/ any opinions? Anyone running or ever run one of these?
Old 12-02-2005   #11
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
John ran his 11.06 on a 60 trim with a 4 bolt housing, .82 AR. The .82 made it a little laggy, and it still had minor compressor surge on spool up. If you punched it 5th it would surge pretty good at around 15 psi/ 3700 rpm, boost would fluctuate up and down 3-4 psi, rapidly. There are better options out there, but it will work and make power. John made 532whp on his, but don’t expect that. Should be good for ~450 like Shane said.
Old 12-02-2005   #12
slowbubblecar
slowbubblecar's Avatar
is that a sc61? If so, I think I know where you found it for sale. I thought it needed a rebuild though.
Old 12-02-2005   #13
nope, this is just a 60trim. A guy I've known for a while that does mostly buschur stuff. This was on his car when he bought it, he ran some 11's with it. I might have to pick it up just for fun, it's a pretty good deal.
Old 12-02-2005   #14
slowbubblecar
Are you not using the mutt anymore? I thought you got a 60-1 rebuilt also.
Old 12-02-2005   #15
yea, I haven't done anything with that yet. I might just sell it, I want something that's in working condition.
