Old 01-01-2006   #1
KrazyTurbo
KrazyTurbo's Avatar
Speed Shifter
Well i decided seince this looks like more of a layed back good quality forum i'd share my new poroject with you guys first. Please dont come in here flameing, constructive critisim only.
Project:
Replace the stock shift pattern with a simple up/down.
Seperate buttons for reverse and nuteral. (will include nuteral saftey switch)
To upshift:
Push in clutch
Tap shifter up
Let off clutch
Downshift is vice versa.
Yes I know other people have made this. But im trying to create a low cost alternative (under $500)
Advantages:
You cant miss a gear (better on tranny)
Shift WAY faster
Firm version for dogboxe's (dont worry about slow shift destorying tranny)
Great for autocross, easier shift
Great for dragracing, worry about everything else not missing your gear.
What do you guys think? I've got everything layed out and myself and 2 other people are working on making this real.
KrazyTurbo is offline   Reply With Quote
Old 01-01-2006   #2
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: Speed Shifter
It would be interesting to see. I'd like to see it..I'd do pull back to go to the next gear, and push forward to downshift..that's how all the pro's do it..and, it works better.
btw, nice avatar..stealer ;-)
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 01-01-2006   #3
KrazyTurbo
KrazyTurbo's Avatar
Re: Speed Shifter
I'll make the shift up/down reversable so you can chose which one you want.
Old 01-01-2006   #4
Re: Speed Shifter
Project:
To upshift:
Push in clutch
Tap shifter up
Let off clutch
Advantages:
Shift WAY faster
I like the idea, and I too think that would be a neat thing to have. Is it something DSMers would spend $500 on? On another note, I know RRE made some things like what you are talking about. It had a digital display to show what gear you are in.
Old 01-01-2006   #5
Re: Speed Shifter
I've heard of this exact same thing being designed for the Ford Focus, but it hasn't hit production yet as it's still being tested. This would be awesome to have if it works flawlessly.
Old 01-01-2006   #6
KrazyTurbo
KrazyTurbo's Avatar
Re: Speed Shifter
It would be simular to the one RRE made. And you could add a digital display for the gear if you wanted. This one would be a quite simple hookup, maybe 15min installation. I think dsm'ers would spend a fair ammount for this, after they see how well it works.
Old 01-01-2006   #7
Re: Speed Shifter
Do you have a like to the RRE setup? I've never heard of it before, but it definitely sounds like something they would come up with. Is your's going to use some sort of two axis electronic actuator system?
Old 01-01-2006   #8
KrazyTurbo
KrazyTurbo's Avatar
Re: Speed Shifter
It's possible
Old 01-02-2006   #9
Re: Speed Shifter
Why hasn't RRE pursued it yet then? They did have it years ago.
Old 01-02-2006   #10
KrazyTurbo
KrazyTurbo's Avatar
Re: Speed Shifter
Unshure, I have a computerized version up and running.
Old 01-02-2006   #11
Re: Speed Shifter
Have fun with this one .
Old 01-02-2006   #12
KrazyTurbo
KrazyTurbo's Avatar
Re: Speed Shifter
it is fun the design and computerized prototype work just fine, now it's time to build an actual prototype.
Old 01-02-2006   #13
Re: Speed Shifter
Realistically I don't think it would be that hard to set up if you're good with VBA(or some other programming language) and control systems.
Old 01-02-2006   #14
Re: Speed Shifter
I know, we were toying around with this idea (using paddle shifters) a few years ago.
Fun, but I doubt re-sellable. A person can feel if the clutch pedal is hanging and if the transmission doesn't want to go into gear. A cable that is ramming a car into gear because it was "told to" has no clue that the transmission isn't "ready" for the next gear.
Old 01-03-2006   #15
CarPsyco84
CarPsyco84's Avatar
Re: Speed Shifter
sounds like broken shift forks waiting to happen, but after their replaced with steel ones and a double syncro 2nd It might work better... It'll be way tight and I'll give you mad props when it all works out...
-When in doubt, Moar RPM.
Old 01-06-2006   #16
KrazyTurbo
KrazyTurbo's Avatar
Re: Speed Shifter
The box wont let the shift take place if there is too much resistance When that happens you gotta try again etc. And you still have to use the clutch.... So you could feel that.
Old 01-26-2006   #17
BoostedTSI
Drives: M3
Re: Speed Shifter
If you can get it to work well I would defenatly pay 500 for it
BoostedTSI is offline   Reply With Quote
Old 01-26-2006   #18
Re: Speed Shifter
i happen to like rowing through the gears on my own. am i the only one?
Old 01-26-2006   #19
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: Speed Shifter
Yeah, I think I'll hang onto the enjoyment of manually shifting my not-racecar.
Old 01-26-2006   #20
Re: Speed Shifter
Agreed; this is one of the things that I think will make the EVO X not as enjoyable. Great for a racecar, but not a fun streetcar.
