Old 04-06-2006   #1
well against my better judgement i decided you all should know...
The DSM is dead, well not entirely dead, but a parapalegic (sp?)
Tonight my tranny gave in so my car will not be moving.
I am sad. someone shoot me.
But tomarrow I may be picking up a new car, a 98 GST, MANUAL TRANSMISSION!! its got some decent mods like act 2100 clutch, DSMLink, 16G, fidenza flywheel, type s, a built 6 bolt by RRE, stage 2 ported head, and some other stuff. It may be my new car tomarrow but we shall see.
Old 04-06-2006   #2
howslowcanyougo
Older than Dirt...
howslowcanyougo's Avatar
Drives: IX EVO MR/SE
Re: well against my better judgement i decided you all should know...
Holy Crap!
So that TCUGO and your lead foot tourched that Tranny in just less than 2 weeks???
WTF!!!
I JUST bought one and now I'm scared to even put that TCUGO in my car?
I need much more details, please man!
What's the REAL and WHOLE story behind this failure?
How hard have you been beating on it? When is the last time you change the tranny fluid and filter? Has it been real hot out down there or wtf?
Let the madness begin...
Old 04-06-2006   #3
Who knows, maybe the tranny was on the verge and this just sent it over. This does suck though, I know it will all work out in the end and you'll be happy with the GST if you're able to get it! I'll even teach you how to change tranny fluid
Old 04-06-2006   #4
npaulseth
Yeah, this scares me as well. Do you know what broke on the transmission?
Old 04-06-2006   #5
howslowcanyougo
Older than Dirt...
From EVERYTHING I've read A/T's are suppose to be tough as nails, but I guess if you neglect std maintenance on anything you run, I'd also guess you can also you can expect it to fail.
I'd be most grateful for the straight dope here, from the horses mouth one way or the other?
What happened Tom?
Old 04-06-2006   #6
Basically what happened, is i had the tcugo off and when it was shifting from 2nd to 3rd it was slipping out of gear but then it would eventually get into 3rd. but then it was getting worse and worse, until it wouldnt go into to any of the gears. so in order to limp it home i had to turn off the car, then turn it on and it would move for about 10 seconds then would slip and wouldnt go back into gear. so im not exactly sure what broke on the tranny.
ok yes i have had the TCUGo for only like 2 weeks, but i really havent been hitting it that hard, ive had it on stage three, never even had it on stage 5. Im not sure but i think the tranny fluid and filter were changed when i had the motor replaced under warrenty. which was about 30,000 miles ago.
Old 04-06-2006   #7
I really dont think that the TCUGO is a bad mod, as long as:
a) you add a tranny cooler, or do something else to the tranny to strengthen it or cool it.
b) use it for only racing
If i could go back and do it all over again i would have still done the TCUGO but i would have done the supporting mods and changed the trans fluid and added a cooler.
Old 04-06-2006   #8
howslowcanyougo
Older than Dirt...
That totaly sucks man, what a royal f@*kin pain!
What are you doing with the old car now?
My TCUGO will be here anyday now, BUT I'm gonna get all the tranny work done before it even goes in, and in your honor am getting a bigger tranny cooler!
Thanks for all the good and Honest feedback Tom, it may have saved my or some elses tranny! <or maybe not? We'll see?>
A moment of silence is in order here for Toms Red 2G with the tire flys and bad side skirts, that he loved and cherished.....
Seriously, I'm sorry to hear this bad news for you man.....:-<
Old 04-06-2006   #9
the red lady will sit in the garage, and some of the mods will come off of her, but one day she will be alive again, the engine is still strong.
Old 04-06-2006   #10
howslowcanyougo
Older than Dirt...
Bet you can fine a smashed A/T car in the boneyard with low miles and get another A/t for cheap?
Or IPT could repair and or rebuild your present tranny?
Old 04-06-2006   #11
GSXMatt
You can't buy my Evo.
GSXMatt's Avatar
Drives: 03Evo,11Altima
Send a message via AIM to GSXMatt
gimme dem rims!
99 GSX- Sold
03 Evo- More than stock.
-ATC Productions-
is dead.
I hate Mitsubishi.
GSXMatt is offline   Reply With Quote
Old 04-06-2006   #12
Tauni
Mazda-ing
Tauni's Avatar
Drives: 2013 Mazdaspeed3
Fuck that. Sell it!! You have that GST coming to ya, why don't you just sell your GSX, drive the GST for a bit, then sell that too and buy a GSX with a manual instead of an auto! IDK if the TCUGO is sellable or not, but maybe that could go to?
Old 04-06-2006   #13
howslowcanyougo
Older than Dirt...
How much is a dead non-running 99 GSK worth?
I say fix it and run it or fix it and sell it, or you'll just loose your ass otherwise!
Old 04-06-2006   #14
Jana
Mazda Bitch
Sorry to hear Tom. Yeah, if you want to do any racing in an A/T, I would highly recommend doing work to the tranny. I didn't even race my car that much, and by the time I was selling mine, the tranny was starting to have some issues.
Old 04-06-2006   #15
howslowcanyougo
Older than Dirt...
Check out below what "Hugo" the ower of TCUGO says about this situation:
Hugo,
Did you see this thread yet man?
Tom already toasted his tranny out in 2 weeks using your TCUGO system?
Making us a bit nervous here man!
http://www.dsmstyle.com/forums/showt...d=1#post131824
Any ideas?
Thanks....
Howie
"He doesn't have anything to do with the TCUGO for severals reasons:
I mimic the pressure signal EXACTLY like the stock TCU. So when you're shifting, it's like the stock TCU. Also he did mention he was using stage 3 which is putting MORE pressure during shift, so preventing clutch slippage, so more pressure mean less wear. That is for the shifting which happen not that often when you're driving around. As for gear control, it's just a 12 volts solenoid beeing controlled with a + or GND depending which gear is selected, again, like the stock TCU. People around here in Canada have been running the TCUGO for a long time in their car, so I'm not worried about that. And to be honest, it's not a 2 week usage of the TCUGO that will toasted it's tranny. For sure there was something before that.
I hope that will clear out some of your concern"
Hugo
Old 04-06-2006   #16
The tranny went bad so sell the car?? Replace the damn tranny! It is nothing any of us manual transmission guys have had to do :rollseyes:
Old 04-06-2006   #17
Yea, no doubt. Quit crying and fix/replace the tranny & get it rolling again!
Old 04-06-2006   #18
Well i have no choice but to change out the tranny, but the simple fact is its a complete annoyance because that car was my primary vehical. So now ill get the GST and eventually fix the GSX and either sell the GSX or just keep it and pay it off, i still owe like 9-10k on it so thats what really hurts.
Old 04-06-2006   #19
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
This makes me think twice about modding a car I have a loan out on. Sucks to hear about the tranny, just switch it out and learn more about your car. Theres always a postive to come with a negative.
Hope it all works out in the long run.
-Colin
Old 04-06-2006   #20
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
you paid 19 for it didn't you?
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
