Old 12-24-2006   #1
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Lack of boost
Ok so the car is a 1991 talon awd, it has less than 2k on the short block, and it has an electronic boost controller which im planning to get rid of for an mbc. The problem is no matter what setting its on it will only run about 6 psi in first and second and maxes at 12 psi in third ect. I checked for vacuum leaks with a smoke machine and took care of the few i had and it still wont boost any more. It has an idle surge also which may be related, havnt figure out why it surges, plans to buy a block off plate but, the question is could it be a bad turbo (14b with unknown mileage on it) or something else. Also this may be a dumb question, but could this problem be related to my lack of oil pressure??? any suggestions are helpful, thanks!
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 12-25-2006   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: Lack of boost
Boost leaks my friend. Also, if you have a lack of oil pressure, you might have a couple more problems than boost leaks at that...
Old 12-25-2006   #3
Bode
Bode's Avatar
Drives: 01 Impala
Re: Lack of boost
If you need a boost leak tester, I have my homemade one I can run up to your work next time you are there. PM me if you need it.
Bode is offline   Reply With Quote
Old 12-25-2006   #4
Enes
Enes's Avatar
Re: Lack of boost
where are you located.? i got a boost leak tester too
Old 12-26-2006   #5
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Lack of boost
im located in eagan? that might be helpful. thanks ill pm you
-Matt
'06 Acura TL
Old 12-27-2006   #6
Enes
Enes's Avatar
Re: Lack of boost
i'm up in Blaine, north of the cities.. work downtown but I haven't gone into the office for last 2 months, just working from home now days ;p
The one i have is perfict for a 50 trim, for a 14b might be a bit too big and might pop off if you push it over 15 psi.. i had it on mine at around 25psi no problem.
-E
Old 12-27-2006   #7
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Lack of boost
-E
hmmm... well i will see what i can find, Bode said he might have one i could use. thanks for the help
-Matt
'06 Acura TL
Old 12-27-2006   #8
Re: Lack of boost
Hrm, I say blame the electronic boost controller. Throw a MBC in there and see what happens.
Old 12-28-2006   #9
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Lack of boost
im thinking its probably the electronic boost controller also, im gonna go out and get an mbc tomorrow.
-Matt
'06 Acura TL
