Old 08-17-2006   #1
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Voltage Issue
I had a problem that I am hoping you guys could help me solve before the show up in Rogers this weekend. I took my Talon out for a short joy ride about a week ago and out of the blue my volts started to drop. And I posted about it thinking it would be the high-output alternator that you guys and my cousin who built it thought it was. Well today I switched that alternator out with the one in my GS which is a stocky and both cars run the same voltage as before Anything was done. But this time While putting the stocky in the talon none of my interior lights work. The ones on the floor, the one on the ignition, and the ceiling. I am really hoping you all could diag. this problem so I could see you all this weekend whoever is going.
Thank you all and sorry this has to be soo long.
Old 08-17-2006   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: Voltage Issue
try another battery? check for corroded wiring and connections on the battery and alt. too
Old 08-17-2006   #3
TsiEagleTalon92
Re: Voltage Issue
Well there is corrosion on the wires coming off the alternator but nothing seems loose or fraying although that is stupid to say since green is bad to see.
Old 08-17-2006   #4
Re: Voltage Issue
Make sure the alternator fuse is good and has a good connection. It is under the hood. Also make sure you have enough grounds connected to the engine.
Old 08-18-2006   #5
TsiEagleTalon92
Re: Voltage Issue
Well I replaced the alternator fuse and my interior lights work again but it still has a low charge. The connections still feel snug. I don't know where to check the grounds on this car to well, but from what I can see they look to be good.
Old 08-18-2006   #6
TsiEagleTalon92
Re: Voltage Issue
The battery is relocated to the trunk and everything is clean and snug back there as well.
Old 08-19-2006   #7
TsiEagleTalon92
Re: Voltage Issue
Int. Lights don't work again and all relays and fuses have been replaced. The only thing I cannot find are the grounds under the hood. Too many things have been moved from the stock loc.
