Old 01-19-2004   #1
npaulseth
Hey guys. I just picked up a 1G AWD four days ago and it's already broke. The engine had 15k on it. Was cruising at 65 mph, just added a quart of oil (the dipstick was broken, so I think I had about 5.5 quarts of oil in the engine. Didn't know that the dipstick was broken till after the car had the oil in it) So, I was just putting along at 65 mph, when the car surged, like a misfire, and then I heard a knocking type noise and the car died. Pull over, start the car, it idles alright, engine was kinda shakey, but it's knocking like crazy. Got it flatbeaded back to my apartment. Took the plugs out, the 2nd cylinder from the timing belt had oil above the threads. All of the spart plugs looked good. Any ideas? Spun rod bearing because of too much oil?? Maybe the timing belt skipped a tooth? I'm going to try and do a comp. test but my thing sucks. Thanks guys. Noah
Old 01-19-2004   #2
I would check the timing belt, but maybe if your lucky you just killed some plugs and wires and it's running on 2 or 3 cylinders. Usually the first thing to go from too much oil is the turbo though. If the oil level in the pan is too high, then the turbo can't drain properly so the oil starts backing up and blows the seals in the turbo.
Old 01-19-2004   #3
JiN
JiN's Avatar
Was this Dane's old car?
Old 01-19-2004   #4
npaulseth
Thanks ecoli. I'm going to drop the oil pan and take off the valve cover to get some more info on what the problem is. Yes, this is Dane's old car. Thanks, Noah
Old 01-19-2004   #5
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
that explains why my t25 is in such shitty shape. Before I bought the car, the oil was 4 inches up on the dipstick. I got the car for cheap though.
7/25/09
Old 01-19-2004   #6
npaulseth
Oh ya, any idea on why the dipstick wouldn't work?
Old 01-19-2004   #7
Raptor
ConArtist
Raptor's Avatar
If you want to have some less invasive diagnostics done, we could drive out there with the boroscope and compression tester and see what it looks like. PM me if you want us to check it out.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 01-19-2004   #8
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Well, all I can think of are quite obvious answers. Broken off too short, not enough oil in the car to register, or the dipstich being stuck in the tube. How doesn't it work? I cannot think of anything very obvious. If you have no idea what you are doing, I would deffinitly suggest having Mike (Raptor) checking it out for you. As far as the timing belt, get out your 10mm wrench and unbolt the top cover. It doesn't take more than 10 minutes. It will be quite obvious if the belt has snapped. Also check to make sure it didn't skip a few teeth.
Why were you putting oil in the car before checking the dipstick? 5.5 quarts is a lot of oil in a 1g. From what I remember, they take about 4 quarts.
7/25/09
Old 01-19-2004   #9
If the car stared but ran rough the belt didnt break... Im sure it skipped some teeth. Dont try and start it again just have mike (Raptor) look at it.
Old 01-20-2004   #10
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
That's a nice offer, Mike. When you guys have come to a conclusion, let me know... I'm curious to hear. I can't believe that happened only a couple days after selling it to you. I never had any problems with it beforehand...
Dane
Old 01-20-2004   #11
dylan
Drives: .
You aren't alone. My engine blew the day after I got my 91 GSX. Connecting rod got mad at the starter so it poked a hole through the engine and bitchslapped the fuck out of it.
dylan is offline   Reply With Quote
Old 01-20-2004   #12
npaulseth
Haha, ya, well lets hope that it's just the timing belt. Raptor, where do you live? Also, I have like no money at all, so I couldn't really pay you that much. Call me at 612-290-1040 or PM me please. Thanks a ton guys. Noah
Old 01-20-2004   #13
Enes
Enes's Avatar
i think he charges like $25 for using the boroscope.... which is very very reasonable considering you will spend 5 hours taking things off and puting them back on and plus other things that you will use in order to diagnose this problem yourself.
Old 01-20-2004   #14
You have no money and you bought a DSM? Well that wasnt a wise choice
If you havent ever done a Timing belt change before its a pain in the butt if you dont have all the right tools. The tensioner is the worst part, so if you are looking to get it fixed it will cost you a couple hundred.... the Timing belt alone is 70-90 bucks.
Old 01-21-2004   #15
npaulseth
Well, I am hoping it's the timing belt. It's going to a shop to get diagnosed. I could do a head swap if it comes down to it. If it's something on the bottom end....God help me. Noah
Old 01-22-2004   #16
So you said in your other post that you drove the car to the shop halfway? I wouldnt drive it if I were you. You could ruin a heck of a lot more than what you did the first time.
Unless you flat bedded it there but then you wouldnt have gone 1/4 of the way...
Old 01-22-2004   #17
npaulseth
Ya, I'm taking a risk. I just need to get it done.
Old 01-26-2004   #18
npaulseth
Well, just talked to the shop. The shop thinks it's something on the bottom end, like a chunk (or skirt) of a piston fell off. What do you guys think?
Old 01-26-2004   #19
eh no. I dont know but they ussually dont fall apart unless maybe the psitons hit the valves so much taht it crakced or something... Im not sure.
I doubt its going to be that good.
Old 01-26-2004   #20
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
What shop is this? How can a piston "fall off"? :bs:
'04 Honda Ricer: stock
