Old 12-14-2006   #1
Chris
Chris's Avatar
Send a message via Yahoo to Chris
6 bolt Swap Question
When using a 1g intake manifold, Where can i find the Brake Booster to T in the MAP sensor ?? Not sure if this is correct info but any help would be greatly appricated.
Also when doing a FULL 6 bolt swap , Do the vacume lines get changed around in a 2g turbo GST ??
Screw the naysayers, DSM power, DSM purity, DSM pride - Go fast with class. If someone doesn't understand it's their loss. This is family. This is Life. This is DSM
Xx Team Annihilation xX
www.TeamAnnihilation.tk
Chris is offline   Reply With Quote
Old 12-14-2006   #2
blageo23
AWD4G64
blageo23's Avatar
Re: 6 bolt Swap Question
Are you going to keep the emissions stuff?
The brake booster line is the BIG vacuum line that goes from the brake booster(behind the master cylinder) to the back of the intake manifold. I did it this way for a min then it looked to Ghetto. SO I tapped into the P teminal on the throttle body instead. ALSO there is a part you can buy that is just for this purpose(I cant find it right now). Also its a MDP sensor not a MAP
