Old 12-24-2006   #1
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Lack of oil Pressure
I did a search and didnt come across and similar posts so here it is, the car is a 1991 talon awd, engine was rebuilt a little under 2000 miles ago with the oil pump replaced. In the morning ill start it and it wont have any oil pressure, if you drive it, it will build oil pressure but if you come to a stop it starts to slowly drop back down to zero. It also isnt all the time it does this sometimes it will be perfect other times ill have zero. Any help is appreciated thanks!
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 12-25-2006   #2
Re: Lack of oil Pressure
Who rebuilt the motor? They should be able to help.
What are you using to gauge the oil pressure.
Old 12-25-2006   #3
Does the oil light ever come on? The pressure sensor may be bad, and it is a different sensor than the switch that says there is no/low oil pressure.
Old 12-25-2006   #4
Bode
Bode's Avatar
Drives: 01 Impala
Check your oil level. It is a DSM, no one goes to, but it goes.
Bode is offline   Reply With Quote
Old 12-25-2006   #5
Enes
Enes's Avatar
most likly the sensor, on 2g's its a clip that falls off all the time.
Old 12-26-2006   #6
Make sure there isn't a dent in the oil pan either. That is what killed the 2g in my garage right now.
Old 12-26-2006   #7
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
no dents or anything, the oil is perfect i just did the oil change, maybe its a bad pressure sensor. the car still runs the same, i just didnt want the worst to happen if it was accurate...(reading the stock gauge)
-Matt
'06 Acura TL
Old 12-27-2006   #8
Try cleaning off the contact for the oil pressure sensor. Mine did that when it got too much oil on it. I've even seen some that just simply read low. Find a good one and swap it out and see if it reads differently.
If I remember correctly, the oil light is from a different sensor, so if that is not going on you probably have a bad sensor.
1G's and 2G's have this exact same problem.
