Old 04-19-2007   #1
GnArKiLl
GnArKiLl's Avatar
2 fast questions..
my new scm 60-1 has a vac port at the bottom it is internaly gated, how do i hook my mbc up to that...
also can a cometic headgasked be reused?
Old 04-19-2007   #2
Re: 2 fast questions..
A cometic can be reused if it is in good shape (once or twice usually) and you can use the port as the feed line for the MBC.
Old 04-19-2007   #3
GnArKiLl
GnArKiLl's Avatar
ok so i just run a line from that port to the mbc then to the wastegate..
Old 04-19-2007   #4
Yep.
Old 04-19-2007   #5
GnArKiLl
GnArKiLl's Avatar
thanx alot!!
Old 04-19-2007   #6
yup yup, just make sure you hook it up the right way!
