Old 02-10-2004   #1
Enes
Enes's Avatar
Well a Mitsubushi sent a letter of recall for
94-98 glaants, 95-99 eclipse, 96-99 spyders
Reason for notice:
Mitsushitty motor sales of america inc has determined that a defect which relates to vehicle safety exists in certain models mentioned above. The lower lateral arm ball joints may be subject to premature wear as a result of water intrusion. This leakage could possibly be from a cut or torn boot or from leakage at other areas of the ball joint. Should moisture enter the ball joint, extraordinary wear could occur. In the worst case, the ball joint could separate from the steering knuckle. This could result in loss of steering control and cause a crash without prior warning.
Contact your Satan for further information and scheduling an apointment, it will only take 20 minutes to inspect and if Satan needs to repair it then it might take as long as 2 hours depending on how busy Satan is.
If you have any trouble getting your vehicle repaired promptly and at no charge, please inform Mitsushitty by calling 888-648-7820 monday - saturday 6am to 5pm PST
-E
