Old 08-14-2007   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Intake Pipe for turbo
I have my car almost done for the Mitsu Cookout. However I am completely lost on what to do for an intake pipe for my turbo. I tried to make the stock one work but it doesn't fit quite right anymore. I also don't want to run a screen over the turbo.
1990 Eclipse
My setup is all SS pipes and the car has a FMIC
It also has a MAF-T So the BOV is vented
The turbo is a small 16G and I want to go bigger later so I don't want to spend a lot of money on this or if I do make one I want it to be somewhat universal so it will fit over another size turbo.
I was wondering is it possible to custom make a pipe at an exhaust shop?
If so what size of pipe and air filter should I be using. I figured I will be buying a universal K&N.
If that doesn't work what else do people recomend. I am kind of on a tight budget....
Thanks
