Old 10-31-2007   #1
GnArKiLl
GnArKiLl's Avatar
balance shaft eliminator kit??
i was on slowboy racing and i was looking for a bsek for a 7bolt and the one they have doesnt say witch motor it will work in.. so i want to know if they are the same?
Old 11-01-2007   #2
v8klla
v8klla's Avatar
Re: balance shaft eliminator kit??
They are the same, you're about to pay too much for that kit though
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 11-01-2007   #3
92Laser
92Laser's Avatar
http://www.store.partsdinosaur.com/product806.html
92Laser is offline   Reply With Quote
Old 11-01-2007   #4
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Originally Posted by 92Laser View Post
thats the one I have and it works just fine!!!
Old 11-01-2007   #5
92Laser
92Laser's Avatar
Works great in every car that I've seen. As far as OEM parts its just personal preference.
Old 11-01-2007   #6
v8klla
v8klla's Avatar
Hmm never seen that kit before. I would personally be a little weary of non-OEM components, but then again your just blocking it off lol.
Chris
P: 763-545-3800
Old 11-01-2007   #7
WTF dude, problem number one is shopping with Slowboy. Go read their intro thread here and see how awesome they are to work with and how cool they are. DO NOT give them money, they do not deserve it!
Old 11-01-2007   #8
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
I used the parts dinosaur kit for my 6-bolt. No problems. In fact, it's nice that you are not using bearings with oil holes. They are solid so orientation is not an issue. Plus it's $15.
Old 11-01-2007   #9
that is the same kit that I have put into every motor that I have done. It is the same as the safty brand one you can buy at oreillys auto parts. I get them there because my bro work's there. They work for a 6 or 7 bolt
Old 11-01-2007   #10
Are the parts dinosaur ones missing the oiling groove?
Old 11-01-2007   #11
The vendors need to stop spamming their goods in the Tech Forums.
Take it to PM's.
Old 11-02-2007   #12
v8klla
v8klla's Avatar
Take it to PM's.
Please note that I also answered his tech question which you have since deleted Yes the 6 bolt and 7 bolt BSE's are the same.
P: 763-545-3800
Old 11-02-2007   #13
Noted.
Old 11-01-2007   #14
GnArKiLl
GnArKiLl's Avatar
i know slowboy kinda sux i have had a go around with them befor but i was just looking to see if the kits were the same cuz i have 2 kits laying around
Old 11-01-2007   #15
The ultra cheap way to do the elim is leave the front shaft in the motor, then cut the rear shaft (as close to the pump housing as possible) then weld the hole or tap it for a M8x1.25 thread and use a spare bolt with some rtv on the threads.
Old 11-06-2007   #16
GnArKiLl
GnArKiLl's Avatar
can anyone give me an idea of how to get the center bearing back in.. keep in mind i am doing this with the motor in the car...
