Old 12-21-2007   #1
BKs50trimGST
Post whore
Send a message via AIM to BKs50trimGST
Idle problems
Ok guys, i've been having this problem since I fixed my 92 GSX and got it running. My idle revs up and down constantly when I start it and all the way until it warms up. The idle gets better when it's warmed up but still does it. I bought a used idle speed controller from twack about 2 weeks ago and I installed it tonight. That seemed to not help it at all, plus now when I shift gears the idle revs up, thus no bov sound. I have an Apexi S-afc that isn't tuned yet, when I bought the car it already had it in it and I haven't messed with it at all. All help with this is much appreciated.
Thanks Brian K.
BKs50trimGST is offline   Reply With Quote
Old 12-21-2007   #2
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: Idle problems
Check the resistance between terminals on the ISC. 1 to 2, 2 to 3, 4 to 5, 5 to 6 (I think there are six prongs, but either way you get the idea)
123
456
Should read between 25 and 30. If it's far from that it's broken and either needs repairing or replacing.
Also, a boost leak test is always a smart idea.
Old 12-21-2007   #3
GnArKiLl
GnArKiLl's Avatar
Re: Idle problems
check the ecu for leaking caps..
Old 12-21-2007   #4
Re: Idle problems
Boost leak test and set the idle.
