Old 02-17-2008   #1
blageo23
AWD4G64
blageo23's Avatar
What Cams Can I Get?
Here is the deal, I need some cams that will work with stock springs. I am going to be building a head with nice springs and valves and whatnot but until then I NEED cams but dont want to switch out the springs. I need to know whats the most aggressive cam I can get on stock springs? Really Im just looking for cams that are better then stock, can use stock springs, and that are cheap or that I can find used for cheap.
2.4l
20G turbo
Stock head
Old 02-17-2008   #2
iceminion
iceminion's Avatar
Re: What Cams Can I Get?
I know it is not common, but you can replace the springs while the head is on the car.
or if you just need some stock cams i can hook you up.
there is absolutely no point in buying 264's or 272's as a stopgap
building a 3000GT AWD Turbo.
Old 02-17-2008   #3
If you want something cheap and used to get Brian Crower cams (their 272 grind will be fine with stock springs/retainers).
Old 02-17-2008   #4
95talonracer
95talonracer's Avatar
Come on do it all up on the first shot it is only money. When are you going to build a head with all upgraded parts?
Amsoil Dealer
Old 02-17-2008   #5
blageo23
AWD4G64
blageo23's Avatar
I just dont have the money right now man and my car needs something other then stock. I have a spare head that I want to slowly build. Thanks for the input guys!
Old 02-17-2008   #6
HKS 272s or BC 272s. It's not like the HKS 272s are a bad cam either.
Old 02-17-2008   #7
dedlewamp
Drives: 4G63
Forced Performance makes several sets of cams that will work just fine with the stock springs as well.
dedlewamp is offline   Reply With Quote
Old 02-17-2008   #8
blageo23
AWD4G64
blageo23's Avatar
They only make 2 that can use stock, FP1 and FP2s.
Old 02-17-2008   #9
Supa_dupa_man
Bimmer Guy
Supa_dupa_man's Avatar
Drives: ///M3
hey man, i have a set of crane cam springs if you would like to buy them, they are brand new, never used! still in box!
MMFTW
Supa_dupa_man is offline   Reply With Quote
Old 02-17-2008   #10
blageo23
AWD4G64
blageo23's Avatar
If I buy springs they have to be dual valve springs.
Old 02-17-2008   #11
Supa_dupa_man
Bimmer Guy
Drives: ///M3
what do you mean dual? they are stiff as hell, and they are the nicest ones crane makes, and i bought them for my 420a, i dont know if they will work on your car or not...
MMFTW
Old 02-17-2008   #12
blageo23
AWD4G64
blageo23's Avatar
Like These 2 spings in one. They are required for the cams I want to get.
http://store.forcedperformance.net/m...ode=DSM-Engine
Old 02-22-2008   #13
blageo23
AWD4G64
blageo23's Avatar
What do you guys think of reground cams? For me these will only to a temp solution til I get my head done.
1998 Spyder AWD
567hp
490tq
Old 02-22-2008   #14
Just stay with the stock ones, the cams aren't that bad. Once you build the head, then go big.
Old 02-22-2008   #15
blageo23
AWD4G64
blageo23's Avatar
When I brought my car to DB he said I NEED cams, So thats what Im basing this off of.
1998 Spyder AWD
567hp
490tq
Old 02-22-2008   #16
Bagel, just slap some 272s in there.
Old 02-22-2008   #17
Well, you need cams to extend the power peak. You don't need cams to have a good running car though. People have made some respectable numbers on stock cams. I would definitely look at doing them in the near future, but it isn't going to cause any problems with your car.
Old 02-22-2008   #18
blageo23
AWD4G64
blageo23's Avatar
I guess I know I dont NEED cams but I dont have any power up top so thats why I want them.
1998 Spyder AWD
567hp
490tq
Old 02-22-2008   #19
Then get the HKS 272's. I ran mine with stock springs and they were fine.
Old 02-22-2008   #20
blageo23
AWD4G64
blageo23's Avatar
The only problem with that is a used pair is like $400. Im cheap . Maybe Ill just skip it and spend my money on other things.
1998 Spyder AWD
567hp
490tq
