Old 06-29-2008   #1
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
It went boom again!
Was out autoXing today and had a b it of an incident.
This is the front turbo. For the most part this is what it's supposed to look like. Minus the clipped corners
Here's the rear turbo. See any problems?
These were upgraded turbo's. They start as stock WRX turbo's (13T) and from there the the 3000GT exhaust housing is machined to fit the WRX turbo. Then the compressor wheel is swapped out. The compressor housing is machined as well. I've also seen mention of machining the backside of the compressor wheel to make them fit in the WRX housing. (the 19T compressor wheel is used on Volvo's in some stock applications). I'm wondering if that machining was done to these, and if it made them weak and prone to doing this. Havn't heard of this happening to any other 3S guys though.
My current thought is to get a pair of 13T's rounded up and put them on. They will be a "downgrade" from what was on there, but still a big step up from stock. I wasn't getting all I could out of what was on there, so I will probably only gain power in the lower RPM, and not lose anything up top. Better for autoX.
Hopefully the motor should be ok. Might have some witness marks from the little bits of aluminum going through it, but I think it might be OK. My initial reason for thinking it was the motor that blew up, was that it was running rough, on 5 cylinders. I've had experience with that, I KNOW what it's like. I'm betting some little bits of AL where holding a valve open, as the last time I started it, it was running on all 6.
Till next time I have some good death pics to post, Happy boosting!
Old 06-29-2008   #2
Re: It went boom again!
Wow, I don't think I've seen a compressor wheel grenade like that before.
Old 06-29-2008   #3
Thats shitty. Good luck fixing it though.
Old 06-29-2008   #4
Maybe you need a better blow off valve. Good luck getting that fixed quick!
Old 06-30-2008   #5
Glad its not the engine like you originally thought.
Old 06-30-2008   #6
You post the most awesome carnage pics! Keep it up!
That'll buff right out though, maybe a lil duct tape and you're set!
Evo3 16g's?
Old 06-30-2008   #7
That was an amazing smoke show, I seriously thought someone's car was on fire.
Old 06-30-2008   #8
Dang that sucks! Hope new turbos solve the issues.
Old 06-30-2008   #9
Ryan you are not suspose to be doing that!
Did you have fun?
Old 06-30-2008   #10
MustGoFaster
I found a Miata to drive for the rest of the day and had a great time. The Stealth was fun for the run and 3/4 I got to do with it. Ran a 74 and a 76 with it blowing up at the end. Somewhat dissapointed in my runs with the Miata, ran 76 on all 3 runs, the last one was clean (no cones) and just .1 slower than my quickest, so pritty decent. I was thinking I would be able to get into the 75's with it, but I think my line was wrong since I normlay drive a power car. I was over 2 seconds quicker than the other two drivers that were running the same car, so I can't complain too much.
Edit:
Planning to fix with WRX 13T's since they will bolt up to what I have in there now, and only run ~$150 each. Should get me some more torque down low and make autoXing a bit more enjoyable in 2nd gear. I had 19T's, wich were modded 13T's.
Old 06-30-2008   #11
that is shitty.
my buddy has the turbo of his sti with super low miles on it you could get for cheap
Old 06-30-2008   #12
MustGoFaster
STI's run VF3x turbos, not mitsu last I knew. It is the regular WRX that has a mitsu turbo on it.
Old 07-14-2008   #13
MustGoFaster
I figured out I had turbo's made with knock off parts. Would have been nice to know that before I bought them. Needless to say I wouldn't have. Knock off's are never as good as the real thing.
Real:
Mine (new):
Old 07-14-2008   #14
Wow, that is extremely obvious. Going to get it together before August 3rd?
Old 07-14-2008   #15
MustGoFaster
I'm picking up my second 13T after work tomorrow, then it's time for a compression test (been forgetting to pick up the tester) and re-assembly. And then re tune. If not I'll just have to find a car to borrow.
Old 07-14-2008   #16
Crazy on the rip-off turbos man. Any chance you can go back to the people you got it from and tell them to eat a dick?
Love the sig btw
Old 07-15-2008   #17
MustGoFaster
I can tell them to eat dick, but that's about all it will accomplish.
Old 07-29-2008   #18
MustGoFaster
Update: Started it up with the 13T's today. Need to clean out the intake pipes before it's 100% ready to go.
Old 07-29-2008   #19
Congrats!
Old 07-30-2008   #20
Good to hear! Going to be at DCTC on Sunday?
