Old 01-18-2009   #1
brando
Drives: gutlass
"micro-polishing"
i kmnow what it is and that you do it to get rid of any imperfections and stresses on the surface of metal. but what i dont know is how its done. so....
how do you "micro-polish" something, such as a crank or transmission gears and such?
Old 01-18-2009   #2
Re: "micro-polishing"
I'm pretty sure they are shot-peened.
Old 01-18-2009   #3
wouldn't that dimple up the surface and they'd have to be remachined anyway?
Old 01-18-2009   #4
http://letmegooglethatforyou.com/?q=rem+polishing
damn that was difficult!
Old 01-18-2009   #5
hahahaha
Old 01-19-2009   #6
brando
Drives: gutlass
obviously it was look at your link, none of that is nearly relivant. but your stupid ass obviously cant read. i was simply asking a question amongst car guys. seeing if anyone was worth a damn, and now i know that you arent. so i guess i have gained something from this.
and yes shot peening would dimple the material. shop peening is used to densin metals and so forth, you actually smash the metal together
Old 01-18-2009   #7
Shot peening is a stress relieving technique, thats all I know. Beyond that I don't know and don't care.
Old 01-19-2009   #8
Had you read one of the thousands of hits that search generated you would have found your answer.
I was being half smartass and half informative, if you cant deal thats your problem.
Old 01-19-2009   #9
You'd probably use a tumble machine with a very fine media.
Old 01-19-2009   #10
brando
Drives: gutlass
thats what i was thinking.
i did read na coup[le of those and found out a little bit about it but most of the hits that search came back with were for rem pollishing or car detailing. im sorry for being a dick i was just assuming you people would get my point about asking on the forum rather than on a search engine.
i did find out that they use a substance called micronite. thats about all i got out of it though
Old 01-20-2009   #11
iceminion
iceminion's Avatar
Factory Mitsubishi cranks do not need to be shot-peened
As for DSM gears....the weak points of the transmissions are the shift forks(replace aluminum with the steel ones), and the GVR4 first gear.
As far as I know, modifying the gears on a DSM is not necessary.
building a 3000GT AWD Turbo.
Old 01-20-2009   #12
The REM/ISF process falls under the micro-polish category.
Very cool stuff, do some reading on it.
Old 01-20-2009   #13
DSM gears break all the time. It doesn't take too much to break 3rd/4th on the 94+ trannies. With some torque, the stronger early 4th gear will shear right off.
Old 01-20-2009   #14
You would know, right?
Old 01-21-2009   #15
Unfortunately.
The older stuff is pretty strong, but I have had customers running low 12s who have broken the weaker 94+ 3rd/4th gear stuff.
