Old 01-18-2010   #1
Twenty8
Drives: 95 GS w/ Turbo
The Shitty Wiring in My Car
So this is my wiring in my car and yes it is a shit show but its how i bought it. Here's my story http://www.mitsustyle.com/forums/showthread.php?t=25288
I would just like someone who can wire to help me out in like a month and a half seeing as how i have to go to court for the title. O its even worse inside so yeah. Help?
Twenty8 is offline   Reply With Quote
Old 01-19-2010   #2
Re: The Shitty Wiring in My Car
Just figure out what everything does, wire by wire, and either re-wire it with fresh wire, or wrap it in wire a wrap harness and zip ties/electrical tape. You might have to pull a bunch of it apart to get it right, but just take your time, go little by little, and check your work each step of the way (make sure the car still runs!).
Old 01-19-2010   #3
^DO it. Sounds like a good way to start.
"DSM's, turning ordinary people into mechanics since 1989."
Old 01-19-2010   #4
Twenty8
im just sketchy about messing something up. i have the directions so i should do that i just gotta muster up a little courage haha
Old 01-19-2010   #5
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Tear into it man thats what i did! Figured all kinds of stuff out. Ive gotten more hands on experience with the dsm then i HAVE IN COLLEGE CAN YOU BELIEVE THAT!!!! Once you fix it every tear every drop of blood all the sweat pays off dude! When i turned the key and the motor started stayed running not missing or smoking like a chimney i was so happy!
Old 01-20-2010   #6
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I hate to say this, but if you don't have the confidence to trace down wires, look at wiring diagrams and such, you probably should get a stock car. That being said, I have confidence that just about anyone can handle a problem such as the one you are encountering. If you took more detailed pictures, showing what wires go to what, we can probably be of more help. That's a terrible picture.
Style's automotive engineer
Old 01-21-2010   #7
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
I have experience with cdi ingition box wiring with the 420a and just about any 420a wiring you'd need help with, I used to run a hahn portfueler and dis-2 cdi box on my 420a-t for controlling fuel and ignition. I don't know if I would be able to make it to woodbury with being as busy as I am with college but id be glad to help with any questions you might have.
Jungy is offline   Reply With Quote
Old 01-21-2010   #8
Twenty8
Alright thanks and maybe if the court goes all good i can get it out to you if worse comes to worse. I will definately hit you up though no matter what happens
Old 01-22-2010   #9
mdost03
Sonic Champion!
Drives: VA STI
Jungy is the go-to guy for anything 420a and boosted.
Long time no see Jungy!
Old 01-26-2010   #10
Twenty8
http://www.mitsustyle.com/forums/sho...678#post321678
I need as much help as i can get!
