Old 04-13-2010   #1
DSM_brother2
Drives: to the shop
intermittion no start questions
im just getting done with my car, how often is it for a ignition switch to go bad? it starts sometimes, them you turn the key and no lights light up on the dash and nothing happens? i had this problem alittle bit last year.
im gonna try a new battery tomorrow. so is a ignition switch a probable cause?
93 talon tsi/ 6 bolt swap
Mitch
Old 04-13-2010   #2
Re: intermittion no start questions
Sounds like some kind of bad connection somewhere? Make sure the battery cables are tight
Old 04-13-2010   #3
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I agree on a bad connection, sounds like my problem when I had a bad ground.
Old 04-14-2010   #4
It could very well be the ignition switch as you suggested. I've replaced one in my DSM, and about 5 more in other cars, same problem.
Old 04-14-2010   #5
If the lights and everything turns off while the key isin the start position, it's not the switch. In that case, it's probably either a starter on it's way out, or a bad connection somewhere between the battery and starter.
Old 04-14-2010   #6
DSM_brother2
Drives: to the shop
when you turn the key only the open door light is on, and it doesnt flash
Mitch
Old 04-14-2010   #7
CarPsyco84
CarPsyco84's Avatar
Um, shouldn't a few more lights be on? like the CEL, coolant light and some others till the engine starts? I think the CEL light goes out when you switch from On to starting with the key, so If that doesn't happen then it is your ignition switch. Otherwise Its probably a bad connection. I fixed Alpha's car earlier this year with this problem, the bad connection melted off the wire that connects the starter motor to the solenoid
-When in doubt, Moar RPM.
Old 04-14-2010   #8
DSM_brother2
Drives: to the shop
updated, i replaced the ignition switch with one from a dif shell, and i also double checked all my connections and it seems to be good. not sure if it was 100% the ignition switch
Mitch
Old 04-18-2010   #9
DSM_brother2
Drives: to the shop
ok, nvm still doesnt work and im out of ideas.
Mitch
